Question about Canon EOS 450D Digital Camera
Canon shutter is stuck on bulb
When my camera is in manual shooting mode, the shutter is stuck  on bulb.  Help!
Never mind, I fixed it. Thanks.
Posted on Dec 11, 2008
I know this is an old post but may I ask how you fixed it? Mine is stuck on bulb!
Posted on Jun 05, 2013
Why does my brand new Canon 6D freeze when shooting in RAW
The question in the title and the first sentence imply to me that you have confused manual mode and RAW format.
Title: "Why does my brand new Canon 6D freeze when shooting in RAWD freeze when shooting in RAW"
First sentence: "My brand new Canon 6D freezes when I try to shoot in manual."
Manual mode means you are responsible for all of the settings related to exposure (aperture, ISO, and shutterspeed). RAW is a specific file format to save the photo. They are independent of each other.
My guess is that in manual mode you have the shutterspeed set to the maximum of 30 seconds. The camera isn't going to automatically adjust it for you in manual mode. If you're new to DSLRs, start with Ae (Aperture priority) or Tv (Shutter priority). In Ae mode, you control the aperture and the camera will select the shutterspeed. In Tv mode, you select the shutterspeed and the camera selects the aperture for you. Start off with Auto ISO. This will help you learn what combinations of settings work well together.
Jun 25, 2013 | Canon EOS 6D DSLR Camera Body Only
EOS 600D in manual modes shutter gets stuck. I have to press the shutter button again to release it and take a picture. Help
Hey there,
I had the same problem, until just a few moments ago. If you have the Magic Lantern installed (just search YouTube, and you'll get some easy instructions), go to the intervalometer, and start the shooting. Then stop the shooting, and the camera should work again.
I wont guarantee anything, but it worked on my camera.
Apr 18, 2012 | Canon EOS 600D Rebel T3i Digital Camera
It seems as if my lens is not working. I getting a black screen when I change to shoot mode.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Mar 21, 2011 | Canon PowerShot S3 IS Digital Camera
Shutter stays open
According to what you say, it seems that you selected B (Bulb) as shutter speed (and MANUAL mode).
First, check whether you are on MANUAL mode ("M"); then, check your shutter speed. If it's really in "bulb" mode, all you have to do is dialing the speed button down to figures that match your subject's light conditions and your other preferences involved in the exposure (ISO, lens apperture).
Feb 07, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Canon S2 Is digital camera not able to shoot pictures
You fail to mention the details of your problem. But as you own an S2 IS, I'll assume that your camera is showing a dark LCD screen, and is taking similar black picture (very common problem for the S2).
A stuck shutter is a common failure mode for digital cameras, especially the S2. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 08, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
When I turn on my Canon PowerShot S2 IS camera and set it to shoot mode, the screen is black. A while back, I was able to get the screen to show by toggling with the camera and constantly turning it on and...
For your model camera, pay close attention to the "UPDATE" at the beginning of the above linked article. Who knows, maybe Canon is actually fixing this problem?
Oct 15, 2009 | Canon PowerShot S2 IS Digital Camera
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon xt
First of all, shooting sports in manual is about the most difficult thing you could ever choose to do. I use the Av (Aperture Priority) and let the camera set the shutter speed. Just set your aperture wide open and fire away. That way, you're not constantly fighting with settings missing great shots. Also, in manual, BULB is simply one of the settings and can't be turned off. It can only be 'not selected'.
Best of luck!
Sep 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
LCD black in shooting mode only
Defective CCD. Just happened with our A610 as well. Oddly enough just had our Canon ZR85 camcorder repaired about 1 month ago (for free) due to this same problem. Sounds like Canon isn't as forthcoming with the A610 tho. We called today and they said $100+ to repair or replace, but the following link seem to indicate that if you're persistent you can get them to fix for free. Now the battle begins ...
http://forums.cnet.com/5208-7593_102-0.html?forumID=58&threadID=243034&start=0
Dec 04, 2007 | Canon PowerShot A610 Digital Camera
Canon EOS 450D  Digital Camera Logo
266 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
