Question about Epson Stylus CX5000 InkJet Photo Printer
My ink prints too dark is there an adjustment on the printer
When I copy something, my ink seems too dark. Is there an adjustment on the printer for this?
  • Pam Dec 11, 2008
    what do you mean by printer properties
    Master:
  • 479 Answers
Yes.there is a adjust ment.go to printer properties and there printing preferences and there adjust the print quality to normal which is set on beat mode so the prints are comming extra dark.
Posted on Dec 11, 2008
Dark pages produced on print or copy
you have a problem with your ink cartridge...go and get a new one...
Nov 09, 2013 | Canon imageCLASS D320 All-In-One Laser...
When copying the page comes out SOAKED in black ink
The cartridge or Toner is splitting out more ink.... Remove the cartridge Clean it and place it again.
Oct 30, 2012 | HP Office Equipment & Supplies
Everything seems ok on my printer but when try to print something it comes very light not dark enough
Generally one can set the "Print Quality" in printer "defaults" often they are noted as, Fine, Normal, Fast Normal, Fast, or similar... now that means the amount of INK on the page, the faster you go, the less ink... the less darker it is. Try setting your printer to it Highest/best quality setting see if that helps.
Feb 05, 2010 | Office Equipment & Supplies
Have riso cr1610 - prints for few copies, stops, displays error code E 04
Ink overflow.. On each end of the drum there is adjustments that can be made to the squeege. This is what scrapes the ink through the screen. These scrapers may be applying too much ink or internally too much ink is in the drum. These scrapers can be adjusted from each end. If you have a hard time getting the copy dark enough try to increase the flow of ink through.. this will take away the ink inside quicker. Another problem could be cheap aftermarket ink. I noticed i had a problem with one supplier that the ink was so thin it actually drips out of the drum when not in use.. The only other solution is to adjust the drum internally if the problem persists. This means removal of the drum to adjust ink flow.. This shouldn't be the problem..
Jul 08, 2009 | Riso Office Equipment & Supplies
It seems like part of the light on the copier has burnt out...can the light be replaced? I get a thick dark streak in a copy or scan but not when I print something. Have replaced ink and aligned...
Light is not burnt out.
Open the feed in section where you feed the documents, and clean the glass that documents are scanned across. It is simply dirty
Mar 08, 2009 | HP Officejet 6310 All-In-One InkJet...
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Tone adjustment
When you give 'print command' a window appears. From that window select 'Properties' besides the name of your printer. a new window opens , from this window select the appropriate tab as per your printer and adjust ink level or set print quality to 'fast' or 'fastest' or 'draft' whichever opion that may be present.This will make the prints lighter. !
Epson Stylus  CX5000 InkJet Photo Printer Logo
393 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
