Question about HP Photosmart M417 Digital Camera
Camera can turn on, but all buttons do not respond and cannot turn off.
Hi, My Hp camera will turn on but none of the buttons respond (I can take pictures, but cannot view them). I can't even turn it off. Also, it has been having battery problems for a few months. It almost always says the battery charge is low, even if I recharge the batteries for 24 hours. I have replaced the batteries, but it has not helped. The camera is a little over a year old and has taken many great pictures. Please help! Emzy
Thanks you!! i did whay you said and worked. I removed the play buttton (blue) and worked. The problem is that if the 2 top bottoms (red an blue) are pressed, none of the rest will respond.
If have any problems go to www.skatox.com and you can ask me.
Posted on Nov 26, 2007
    Problem Solver:
  • 5 Answers
We have had a similar problem, and read the first solution, without too much success, however while looking at the button board on the back the two top button tops were not centred as they should be. A right fiddle with the much present selotape, and the buttons looked much better and the camera worked AOK. I presume that when the camera processor does its initial dusting and polishing, sorry housekeeping, it gives up if it finds a button contact permantly made! Many thanks to the website, and the initiator, for the fix!
Posted on Jul 31, 2007
I had the exact same issue and the above solution did not work for me as I could not access any of the menus to try to make this setting change. My attempt to see what was causing this issue began with taking the camera apart by removing the six screws on the bottom and sides of the camera then using a small flat screw driver to gently pry the front and back of the enclosure apart. This obviously exposed the internal electronic workings of the camera. After a close inspection of contacts on the circuit board for the external buttons I found that one of the small metal contacts, which are held in place by a piece of tape, had slid down and was causing a short. I removed the tape, placed the metal contact back in it's original location on the board and replaced the tape to hold it in it's place. I then reassembled the camera and it works as good as ever.
Posted on Jun 21, 2007
I had the exact same problem, and i had no luck finding a solution, so i was messing around with it, and i figured out what the issue was. Go to Menu and then to the SETUP option. When you scroll down there should be a USB option. Change it from Digital Camera to Disk Drive, and your computer/camera will register that it has a card in it!
Posted on Jun 01, 2007
I have a New Canon Rebel T2i. Last night, after downloading photos to my computer, directly from my camera, after unplugging the Camera from the computer, my camera froze. I can't turn the camera off,...
Sounds like you unplugged the camera without using the "safely remove hardware" function on your computer. This corrupted your camera. Go into the menu and find "reset"...see if that helps. If not, remove the card and battery....press every button....leave it alone for 20 minutes...insert the card and then the battery....turn it on.
Oct 04, 2010 | Canon EOS-20D Digital Camera with 17-85mm...
When I turn on the camera the red light on top of the camera flashes all the time and none of the buttons work, then the camera just turns off. I have had the camera for about 3 years. What can I do. The...
You'll be trying for another 3 years unfortunately.
I have the same camera and have the same problem.
Bought a new battery, new charger, new usb cord,
downloaded all drivers, read all manuals, contacted
SVP support 5 times and they never responded.
Now I have thrown the camera in the fire and am helping
everyone else who owns a SVP camera to warn future
buyers of their CRAPPY products that never work!
Aug 09, 2010 | SVP DC-12V Digital Camera
Moultrie camera locked up.
THROW IT IN THE TRASH! NO MORE PROBLEM.
Nov 26, 2008 | Moultrie MFH-DGS-100V2 Digital Camera
Devise not responding
The same thing happened to me,
turn your camera on, hold down menu/ok button, click over to the wrench tool which is called the setup menu, scroll down to USB Configuration, click on it, then scroll to disk drive and select it.
Now try turning your camera off and then back on, connect USB cord to computer and you should be all right.
Nov 11, 2008 | HP Photosmart M525 Digital Camera
Camera Frozen
Try to set your shutter speed you can do this by selecting (S) at the mode dial....
Thanks
May 25, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
R707 locked in the video mode
remove battery pack and memory card then replace should work.
May 05, 2008 | HP Photosmart R707 Digital Camera
Camera Frozen - none of the buttons are responding
sir u remove ur battery and wait some time reset the battery
Jan 03, 2008 | Nikon Coolpix S51c Digital Camera
Problem with HP digital camera. Urgent. please help me out
Do get onto HP Tech Support. It may be a fault they will deal with out of warranty- certainly they will know about the problem
Jul 05, 2007 | HP Photosmart M307 Digital Camera
HP Photosmart M417 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
