Question about Canon MP610 Photo All-In-One Printer
Can't enable Bi-directional support for Canon MP610
Hello all,
I just bought the Apple Airport Extreme N Base, and was initially very excited to see that it had a USB port which supposedly allows for network sharing of printers and/or hard drives.
Unfortunately, when I attempt to print to my Canon, it gives me the error "Cannot communicate with the printer. Turn Enable bi-directional support on in the printer's Properties dialog box." I went into the printer properties, then ports, and saw that bi-directional support is off AND grayed out, so I cannot even select it. The apple airport also can detect my hard drive size in GB, but it is not accessible. Both the printer and hard drive are connected through a USB hub to the Airport Extreme.
I have Windows Vista 32 Bit operating system and a Toshiba Satellite, their new Fusion line.
Any help will be much appreciated... Thank you!
  • 8 more comments
  • Anonymous Dec 24, 2008
    I have the same problem, with Cannon MP210 under win XP. It worked fine until I upgraded windows from service pack 2 to service pack 3.
  • Anonymous Jan 13, 2009
    Same problem here. I never thought about it being related to update to SP3. I guess we'll have to go back to Microsoft with this one.
  • peckwater45 Feb 02, 2009
    Same problem under Vista SP1. Worked fine whilst attached over network but not since attaching direct. It was previously attached to an XP sp3 machine)
  • danweis Mar 03, 2009
    Same problerm with Vista and a Canon MX700 milti-function printer. I have it attached via the network drivers.
  • mikeBox Mar 04, 2009
    I've the same annoying problem
  • Anonymous Mar 13, 2009
    Same Problem as above, tried it on 4 different computers. Windows XP home and pro, SP3
  • Zionblue Mar 25, 2009
    I have a Canon MX310 All in one Scanner, Printer, Fax Running on Windows Vista Home Premium. The computer is an HP Pavillion Media Centre Edition mf8400 Phenom Quad Core Processor Blah, Blah Blah. I did not have this problem while the printer was on my custom built AMD with an ASUS K8V-X Motherboard running windows XP. However it seems nobody is offering solutions. I too get the yellow triangle with the message saying "Cannot communicate with the printer. Turn Enable bi-directional support on in the printer's Properties dialog box." Of course when you go intot he printer Properties Dialog box and you click on the ports tab, and you look way down near the bottom you can see the wonderful little check box with "Enable bidirectional support" beside it... Wouldn't you know it, it's grayed out. YET another wonderful Microsoft Product that doesn't work. If you have a solution, please email me at shawn@genesistechnologies.ca; I would appreciate it.
  • brycefarlow Apr 02, 2009
    Yup. But mine still prints, odly enough.
  • kelocklear Apr 07, 2009
    I have a Canon MX700 and it will not print from wireless connections and I can't enable bi-directional support which is the error it gives me.
Go to cannon website and download new drivers for windows 7. Had the same problem and this fixed it right up
Posted on Jan 10, 2010
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Apple computers will not connect wirelessly to sky broadband
Please open Finder, then go to Applications, and Utilies, then to Airport Utility (Only if you're using airport basestation), and before doing that, make sure Airport is turned on / enabled. If none of this works, this means either your laptop's airport unit / antenna is faulty, or the source of the internet connection. Also, one thing to try is under system preferences, find networks, and if none are there, or airport isn't there, add a new airport and that should help if all fails, if not good luck.
Jul 13, 2009 | Apple AirPort Extreme Base Station
Airport extreme stopped, front light dead, back lights flash
Your airport just died, contact apple support and request a replacement.
Jun 21, 2009 | Apple AirPort Extreme Wireless-N Wireless...
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Need to hook my airport extreme to a netgear switch and isnt working
Go to System Preferenced/Network and configure your new Airport Extreme card. Download and install the Airport Extreme Enabler from Apple in order to use the card in 802.11n mode. Reboot you Mac.
Oct 10, 2008 | Computers & Internet
Cant connect to internet with Airport Extreme 802.11n
An airport extreme is just a dunb Wireless Access Point. It could be that it has been mated to the Linksys router and is looking at a different set if IP addresses that are not coming from the etherent connection out of the wall.
If you know how to obtain network addresses on your computer, find out what you get from the wall jack and from the airport through the Linksys. You can try to reset and reconfigure the Airport, but if you are not familiar with the hardware, get someone who is to help you. The manual offers several tips and procedures to do this http://manuals.info.apple.com/en/AirPortExtremeBaseStationSetupGuide.pdf
Carl
Oct 09, 2008 | Apple AirPort Base Station
Canon MP610 Photo All-In-One Printer Logo
12,398 people viewed this question
old marine
old marine
