Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
My Honeywell 8501 thermostat has
My Honeywell T8501 thermostat has no display
  • Cdaligou May 02, 2009
    My Honeywell T8501 Chonotherm IV Thermostat has no display and AC is not working. Do we need to replace the thermostat?
  • 478 Answers
Ceck for a full condensate pump or a float switch at the drain pan. In most cases we set these up that way to make you aware of a problem. Often the condensate pumps get slimy and need to be cleamed yearly.
Posted on Mar 12, 2009
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? '
Dec 05, 2010 | Honeywell Heating & Cooling
The display on my honeywell thermostat is blank, what do I do
Hi, Check the batteries and replace as needed or check for power from the air handler/ furnace...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
Sep 18, 2010 | Honeywell Programmable Thermostat Heater
My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
244 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
