Question about RCA 27F530T 27" TV
Picture goes dead after 5-10 minutes
Television Displays full video and sound for 5-10 minutes after which the picture zaps out into the middle and the screen blank. The sound operates normally afterwards but no picture. When you turn the TV off and on the picture comes back but problem persists. Heard this could possibly be a comb filter prob? I work in electronic but not TV's so I am unfamiliar with the some particulars of this cuircuit. Sounds like something is overloading and shutting down.
    Novelist:
    Champion:
  • 236 Answers
You may have a loose solder joint causing this problem. If you can take it apart, you mihgt try spraying circuit cooler in various parts of the circuit but NOT in the high voltage or horizontal circuits.YOU MAY CAUSE AN ARC OR A COMPONENT TO SHORT SINCE THE SET HAS TO BE IN OPERATION WHEN YOU SPRAY. If you hit the bad connection the picture will come back on. When the picture zaps to the middle of the screen, is there just a bright line? If so, then you have a loose connection or a temperature problem in the vertical circuit. Stargazer
Posted on Mar 10, 2007
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Video comes on but I lose the picture in 3-5 minutes, screen goes blank.
U still have sound,when screen go black?Than ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 17, 2010 | Vizio L37 Television
Sound but no picture, has worked for 4 years and went black. Cycling power displays video for a half second then goes black again.
LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get the picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Feb 28, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
LCD TV PICTURE STAYS ON FOR 45 SECONDS THEN GOES OFF FOR 3 MINUTE
video board is shot, providing u still have sound. must replace.
Jan 27, 2009 | Dell W1700 17 in. HD-Ready LCD Television
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
When sound & picture finally comes on the picture is pink and in the middle of the screen
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the no audio/video and video shrinking problem.
Sep 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Picture goes into multi coloured vertical lines
have a tech check your tv your problem is in the video circuit could be a cold solder or a component is damaged and need to be replaced.good luck.
Apr 15, 2007 | Philips 32PF7320A 32 in. LCD Television
RCA 27F530T 27" TV Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
