Question about HP LaserJet 2550L Printer
Black lines on paper
Left side of paper prints a thick black l ine
  • 81 Answers
The problem is either with your black toner cartridge or the drum. Try changing the black cartridge first, and if this doesnt work then you will need a new drum
Posted on Jan 03, 2009
VIZIO 42" tv has thick black vertical line on left side of screen
The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
Feb 23, 2013 | Vizio 42 in. LCD TV
Lexmark E120. When it prints it leaves a thick black smudge about 1/2-1 inch thick down the entire left side of the paper in waves. Is there away to clean something or replace something to correct this?
It's time to take your printer to a professional technician, to trouble-shoot and fix this problem,
if you don't know how to do this by yourself.
Jul 30, 2011 | Lexmark E120n Laser Printer
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
My pixma mp 150 shows me E 2
Error E2.
Action : Reload the paper correctly and press [Black] or [Color].
Loading Paper
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
- Set the Paper Thickness Lever to the correct position for the paper.
Important : Make sure the stack does not exceed the Load Limit Mark.
Hope this helps.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Scanner/Printer imageCLASS MF6550
Does it do it on prints aswell as copies?
If so open up the Left hand side door if you peer inside at the fuser (hot bit) can you see any damage. if so needs replacement.
Also could be the drum, look in the same area at the green/blue cylinder, these do up to approx 30,000 pages.
Hope this helps.
Mar 26, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Black ink marks on prints from Epson R380!
Hello:
I have been having this problem all day today and believe I resolved it. The photo paper is thicker (I'm using the Ultra Premium Photo Paper by Epson). I have an Epson 1280 photo printer. I opened the lid and moved the lever to adjust for paper thickness, and voila––no more black ink tracks down the one side. Since photo paper is thicker, this may be your problem as well. Check your manual and see if there's an adjustment for things such as printing envelopes and change the setting. Hope this works for you! I wasted about 6 sheets of paper until I thought to adjust for paper thickness. Please let me know!
Susan
York, PA
smfree@comcast.net
Mar 26, 2009 | Epson Stylus R380 InkJet Photo Printer
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
HP LaserJet 2550L Printer Logo
167 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
