Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Scanned images include darker strips
Hi, lately my PE16 scanned images include darker strips, as if the scanner-head lighting has segments of alternating luminosity. The picture is otherwise OK. Any ideas? Thanks!
  • Erez Manor Mar 04, 2007
    I tried cleaning the glass (both sides), the light-source mirror, even the light-source... Still stripes.
    I attached a scan of a uniform-color cardboard, the stripes are apparent.
    Perhaps the CCD is bad?
  • 4 Answers
Hi, Clean the small scannerglass. every dot on the small slass becomes a stripe.
Posted on Mar 04, 2007
  • Nico Kamphuis Mar 04, 2007
    maybe the ccd is bad,
    Or you need to greese the rail of the mirror
What can I do about black spots on scanned images?
Have you cleaned the scanner glass bed lately?
Apr 26, 2017 | Office Equipment & Supplies
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Document is scanning upside down
Easiest way to confront this problem is to rotate the material being scanned.
If you find the image of the item is being inverted then simply rotate the material being scanned by 180 degrees.
Additionally most scanning software will have a ROTATE function where you can rotate the image of the scanned material, usually in 90 degree increments which can be useful for editing purposes. You may find this function under Edit or Image in your scanning software.
Good luck! William
Mar 02, 2011 | Canon DR-2050C Path-Through Scanner
HP 5470c scanner leaves lines on the scanned
This is often caused by dirt or dust on the imaging head. This requires taking the unit apart in a CLEAN area and wiping off the head with lens cleaner and a microfiber lens cloth.
Apr 16, 2010 | HP Scanjet 5400c Flatbed Scanner
Scanner is jammed
There is usually a scanner lock button on these units, either located under the Auto feeder on the left side, or on the left side of the machine
Jul 17, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
All the slides scanned are darker than the original
The problem is internal see this website for cleaning an Hp scanner but your problem is similar http://www.willshak.com/scanner/
Apr 19, 2009 | ACI Pacific Image Prime Film PF3650 Pro...
Faulty scanned images
Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
Stripline on my scanned images from Minolta 5400 II film scanner
If some particles of dust stick to the scanning module, then while scanning they appear like lines. Clean the scan module thoroughly using Isopropyl alcohol IPA-Industrial grade is enough, dont use any solvent. You can use your aftershave (!) once or twice. Ensure that the film strips are not sticky.
S. Mohan, Chennai, India
Nov 21, 2008 | Office Equipment & Supplies
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Streaks in image scanned by Canon DR-2580C Path-Through
The staples cannot reach the sensors. They could have scratched the glass above the sensors. Clean the glass with IsoPropyl alcohol. Try scanning a few images to find if the scratch marks are on the same place on all images. Once confirmed that the glass is scratched, you can change the glass. You need a technical expertise to change or call service staff.
May 29, 2008 | Canon DR-2580C Path-Through Scanner
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
126 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
