Question about E-Machines T5212 PC Desktop
My T5212 does not connect to my printer?
My computer was hit with lighting 4 mo. ago. I had to replace the ethernet card, is there also a card for the printer hookup? The computer keeps telling me, my printer is offline????
  • sandra_green Dec 11, 2008
    What is a PCI card. As you see I know nothing about these monsters....
    I will get help from my son, I am not sure myself
    if it will work or not, but I appreciate your help either way. Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls post the brand and model of your printer.
Basically, most printers (except the new wireless) needs some form of wired connection to the desktop's motherboard to receive the "data" it will print as well as general status information such as being "online". This could either be a USB or LPT1 as the most common. So depending on which of the two, that particular section of your motherboard needs component level check-up or alternately a replacement motherboard.
If you are considering a DIY (do-it-yourself) repair, foremost to check would be the BIOS configuration to determine if these ports are enabled and/or detected by the motherboard prior to Windows booting. This being so, then Windows upon boot can load the drivers. If even at the BIOS stage they could not be detected, then Windows will not load them and any device that uses that port will appear "offline" to Windows.
There are instances that a fusible link or surface mounted jumper/resistor burned and thus is open making any of these ports inoperable. A continuity tester and familiarity with electronic components and circuitry would be invaluable in determining if these is a case of missing +5VDC in the USB, inductor links for the LPT1 or the ICs that serve as buffers/interface.
Of course as earlier stated, a replacement motherboard would be the easiest way out.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
  • 275 Answers
Try uninstalling the printer software and install it back with its software CD, then if that does not work try checking for the printer connection on the Device Manager and refresh the connection...good luck... i dont think you would have to replace it tho.. if it had burned you would've had to replace the whole mother board, trust me!
  • Alan R
    Alan R Dec 11, 2008
    Dont worry about PCI card you dont need to know all about that, since you dont know what it is, it's obvious that your computer does not have one, just do the above steps and you'll be fine
  • E-Machines Master
  • 19,396 Answers
If the printer is hooked up using a PCI card, replace the card.
  • Ginko
    Ginko Dec 11, 2008
    Normally the printer is connected to the computer using either the USB port or (on old computers) the parallel port, both ports are built into the motherboard, and normally not on an external card.
    More likely your printer had lost connection to the computer, and you will need to reinstall the drivers and software using the disk provided with the printer.
    Inplug printer USB, reinstall printer software using printer cd. The software setup wizard will tell you when to plug in the printer USB.
    Try that , if it does not work, test the usb port with a different device, for example a memory stick.
Lighting hit my gateway computer, now cant get on line
It's a wonder it works at all, you do not have a surge protector? You may have fried the ethernet card. I suppose you could get a wireless access point and a wireless card or wireless USB device for the computer. Are you sure thats all you lost?
Nov 20, 2012 | Gateway 310 S PC Desktop
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
What ethernet card to install Dell Optiplex GX 240? one attached to mo works intermittently - loose.
You can use any brand of Ethernet card in this computer as long as it will fit in the case. If your GX240 is packaged in the small form factor case, you'll need a low-profile card. (Low-profile cards have a shorter mounting bracket than regular-size cards which won't fit this case.) For the small desktop and mini-tower cases you can use any card.
If you want to avoid having to open the case and fit a new card, consider a USB Ethernet adapter. All you need to do is plug it in to an available USB port and you're done. No opening the case and worrying about installing a card. These adapters are available at some retailers and through online vendors.
Whichever way you go, just be sure to go into the computer's BIOS settings and disable the integrated network connection.
Hope this helps. Thanks for using Fixya!
Feb 15, 2010 | Dell OptiPlex GX240 PC Desktop
Ethernal Controller Problem
click start
click connect to
show all connections
look to see if lan or high speed internet shows connection.
If enabled and not working look on back of computer to see green light from ethernet plug.
if no green light try different ethernet cable, if that doesn't help replace ethernet card less than $20
Mark
if you need more let me know
Apr 11, 2009 | Gateway GT5220 PC Desktop
Looking for a compatible Driver for my Ethernet connection
Open up device manager> double click on the unknown device> go to the details tab> in the drop down choose hardware id> google the alpha numeric code on the first row before the & symbol (ex- PCI\VEN_14E4)
That will give you the make of the ethernet adapter you have on the pc. Once you have it installed you can patch up the wireless as it works on the network adaptor base which generates the ip address.
Hit me again if this dosent do the trick.
Feb 18, 2009 | ASUS M2V Motherboard
Integrated Ethernet Port Fried/Trying to Reformat
Try going into the BIOS when the computer starts up (F12 at the Dell Screen I think) and disable the onboard ethernet and see if that helps.
Jun 10, 2008 | Dell Dimension 2400 PC Desktop
US doesn't stop blinking!!!
Heres how i install my modems
1.Turn off all equipment
2. Take an ethernet cable going from the modem, and plug it into the ethernet slot on the computer.
3. plug in the modems power and give it 1 min to power up.
4. Power up your computer and see if it gets connection.
Troubleshooting.
1.Go to the control pannel and look at internet connections.
2. Look for your connection (LAN), and see if is connected.
3. If it isnt connected than it is a problem on your ISP's side.
For other support
1. Call your internet service provider for help.
2. Call the customer support line for the modem.
May 09, 2008 | Linksys EtherFast Cable Modem with USB and...
Brother 2700CN Color Laserwriter--Loss of Ethernet Connection
No lights on network card mean that you will need to replace network port/card on printer if cable and connection is sound
Nov 28, 2007 | Office Equipment & Supplies
E-Machines T5212 PC Desktop Logo
16 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
