Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Brother FAX 4750e - Fails to access 2nd tray
THe scanner portion has a defect, so this unit is being used as a printer. When trying to print to the lower tray (2) which has legal paper, it will not select that tray even with settings on "auto". When you try to specify the lower tray manually, you get the following message:
There are one or more conflicting settings.
One of the conflicting settings is:
Paper Source:Lower Paper Tray
Lower Paper Tray:Off
Resolve conflicts automatically for me (radio button at start of line)
I will resolve the conflict myself (radio button at start of this line)
However, no combination of re-setting the settings on the machine or changing via the driver force it to go to tray 2. Emptying tray 1 of paper will force it to use tray 2. I can't get it to work any other way.
thoughts?
thanks
  • 186 Answers
SOURCE: Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Posted on Jun 21, 2007
Guru Guy
  • 95 Answers
SOURCE: paper jam inside
You may also have a problem with the paper feed (clutch, dirty feed/pick up tires) section, or even a dirty sensor as Jay mentioned. A sensor in modern office equipment is generally a photo sensor, which means it shoots light from one side to be detected on the other side of it. If it's dirty, it will give you a flase reading. Try cleaning the tires that pick up the paer from the tray (don't force them down if they won't rotate easily) with mild soap and water on a rag, and also try fresh paper. Sometimes if paper has been sitting for a while, or in damp conditions, it will pick up moisture and give you paper feed problems... which is what it sounds like you are having. Sounds like the paper may need even be making it to the sensor in the 1st place if it on comes out of the tray 1/2 an inch. Good luck
Posted on Dec 27, 2007
SOURCE: no longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Posted on Apr 18, 2008
  • 101 Answers
SOURCE: Brother Intellifax 4750e with black line (1-1/2" wide on right)
The drum is scratch ,or there is a paper jammed .
Posted on Apr 22, 2008
leroyal
  • 2120 Answers
SOURCE: Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Posted on Sep 12, 2008
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
How do i get to print my web stuff coz my brother MF-J470DW is sending blank papers without prints
If you machine prints other things without problem, then you should be more specific about what web stuff you are trying to print. Often web based images are in frames or links, and these can be very difficult to access or print. You may need to download or screen-dump the content before trying to print it.
Dec 02, 2014 | Brother MFC-J470DW Inkjet All-In-One...
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
We have Brother 4750e that says "printing online" but nothing is coming out? Can send a fax but will not recieve a fax? Any ideas?
Un plug the unit and see if it will reset it self. Oh make sure the phone line is in the correct port.
Aug 11, 2010 | Brother IntelliFAX 4100 Laser Fax
Printing on line
try unplugging the machine then replug good luck
Jan 28, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Can't find info - comfirmation
Its called "Transmission Verification Report"
Press Menu, 2, 4, 1
Select ON or On+Image
This will come with every fax you send.
If you want to customize, see owners manual under, "Printing Reports"
Oct 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
When we copy on our 4750e fax it comes out with black page
Can you see light from the scanner unit with you make a copy or try to send out faxes? The bulb for the scanner may be burnt. You might be able to find a replacement bulb, search google or contact Brother.
Jun 16, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
IntelliFAX 4750E - Printer Busy
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Jan 02, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
