Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Power nuzzle keeps stopping
Power nuzzle start then stop
  • 2,976 Answers
Get a new "Short Cord". These have a habit of going bad at the connector. Only a couple of bucks.
Posted on Jan 01, 2009
My Dyson DC35 stops after the first minute. Then it keeps stopping every few seconds. I checked for obstructions, washed the filter and cleaned the brush. Is it the batterie?
In the inlet pipe, there is a small valve that can get jammed shut with debris this causes them to pulse start, stop, start, stop, and so on. Ensure this is floating free, not jammed shut, it works purely on gravity... The other possibility is the cyclone needs cleaning. Remove the filter and check no dirt is lodged there. Remove the top torx screws and keep them safe. Carefully remove the top check for damaged seals gaskets etc (this can cause a malfunction). Again keep safe. The cyclone can then be inspected for dirt and dust clogging holes and airways. Clean thoroughly and reassemble, make sure all components are dry if they have been washed to clean them. Hopefully, this will restore the machine to working order
Feb 09, 2018 | Dyson Vacuums
My rainbow stop red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Room a 620 keeps stopping
It could be clogged with hair (when was the last time you cleaned it out?), it could be the battery isn't holding a charge any longer. It could be getting caught on something . How long is it running before stopping? I found I used to get about a two hour run from my Roomba, before the red light flashed. Then I started to unplug the charger and Roomba when it had a full charge and it wasn't needed. I noticed that after this the Roomba didn't run as long, maybe one hour, before needing a charge again. I leave it plugged in all the time now.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
Eureka powerline umc-18 vacuum quit working
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Dec 18, 2013 | Eureka 1810 Central System Vacuum
DC44 Animal Cordless Vacuum power cuts on and off while trigger is pulled
This doesn't address the intermittent power cut offs...power cuts off intermittently and you have to keep recycling the power 'trigger' to get it to PIA
Dec 17, 2012 | Dyson DC44 Animal Cordless Vacuum
Hi my dyson keeps stopping and starting
It is stopping probably because it has a blocked filter. Down on the right of the machine is a filter. Press the coloured button to get it out. Wash and dry it and see how that goes.
Jan 25, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson stopped working.
Have you tried starting it again? It might have stopped because it overheated and now that it has cooled it should start again. If not, then possibly the power switch or power cord has failed.
May 26, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
its overheating check to see if its cloged any where look behind brush roller
Feb 08, 2010 | Vacuums
When I turn it on it doesn't start out in the circle motion but starts and than stops and than starts and than stops and moves erratically and than totally stops.
Try a different battery. If no go, you might have bad board or sensors. Basically, if the battery replacement doesn't fix it, get rid of it. Borrow a battery from someone else so you're not wasting your money for testing.
-=/ Daft Tech /=-
Oct 25, 2009 | iRobot 5800 Scooba Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
59 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
