Question about Tilia FoodSaver V2240
V2240 doesn't seal bags with liquid in it
All it does iw vacuum the liquid out and doesn't seal.
Tried seveal things, incl. putting the bag in a second bag.
It's SUPPOSED to work for this...
  • Anonymous Mar 19, 2014
    Will not auto seal bags after vacuum
You can not vacum liquid. If you do soups or stews freeze first in plastic container and pop out and freeze frozen food in bag. Also when doing fresh meats freeze just enough to solidify the jucies about 1-2 hours them vacum. I have had mine for five years and through trial and error have found this works excellent. Hope it helps, good luck.
Posted on Dec 13, 2008
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 | Vacuums
Foodsaver troubleshooting
The same thing happened to mine and I found a really,really inexpensive way to resolve it. I don't use original foodsaver bags and I found out that their thickness might not be detected correctly so it won't vacuum. To compensate for this, I used an ordinary piece of notebook paper. I cut it to a size of 4 1/2" by 1 1/2". I set the long side in the middle of the liquid catching tray and let it lean back towards the heat strip. Make sure it doesn't cover the heat strip or it won't seal. Now I inserted the bag as the directions say, close and lock the top, and it vacuums and seals perfectly. b40a3e78-1fd3-4c38-9291-c5c4e3885648.jpg
Jan 05, 2014 | Kitchen Appliances - Others
Why does my rival seal a meal not seal?
The sealing mechanism is not working properly. Make sure there is no debris in the path of the seal wire - if so the area under that material will not be sealed and there will be leaks.
Sep 15, 2017 | Kitchen Appliances - Others
When vacuuming out air, the liquid is vacuumed, inside of the bag where it seals is wet, and it won't seal.
Try placing a folded paper towel in the bag between the item and the area of the seal
The towel will absorb the liquid allowing the bag to seal but keeping the liquid in the bag
Feb 05, 2011 | Rival VS230 Seal A Meal Vacuum Food Sealer
The V2240 does not seal or vacuum at this particular step. The motor runs, the unit buttons are working but the vacuum, sealing action does not work..... Any ideas ..... And yes It was plugged in !
It's possible that liquid is getting into the sealer or the seal is dirty. Here's a link for a pdf that explains possible problems and solutions.
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Dec 11, 2010 | Tilia FoodSaver V2240
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
Food Saver quit working.
i have a game saver plus. when i start the seal light comes on then it sucks the door closed then the seal light comes on again and the door opens and it stops
Jan 08, 2010 | Tilia FoodSaver V2240
How do I turn on my tillia foodsaver my friend lent to me?
Put food in bag. Open lid using latch to right if necessary to release. Put bag in sealer. Close lid. Close latch. Push vaxuum or seal to activate
Sep 28, 2009 | Tilia FoodSaver V2240
What is a heat seal I see one on ebay but say it needs heat seal what are they talking about were can i get one or some for thev3825 foodsaver
the function that seals the bag after the vaccum process (melts the plastic to itself) Hope this helps
Jul 13, 2009 | Tilia FoodSaver V2240
Tilia FoodSaver V2240 Logo
558 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Tim Doolittle
Tim Doolittle
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
