Question about Whirlpool GEW9868K Electric Dryer
Dryer will not start
Did what you suggested and still no power? What next
  • 4 more comments
  • Ralph Jones Mar 04, 2007
    Display shows nothing.no indicator lights on the control panel at any time.no lights when the door is opened, checking with the ohm meter it shows power is getting to the dryer and to the connections,pressing the buttons on any of them gets no responce. I really appreciate your help.
    Slats
  • Ralph Jones Mar 05, 2007
    When checking for power and light in dryer I found the bulb to be burned out. put in new bulb and revisited your earlier suggestion saying if the light is on in the dryer and all else checks out then it must be a bad control board,I sure agree,and sorry for being so stupid not to check the light bulb. There was a lot of effort on your part to help me, and I sure appreciate it.
    I have ordered a new control board.
    Slats
  • Anonymous Nov 29, 2007
    i have same problem repacedboard and nothing i am lost
  • fukmaster Apr 11, 2008
    dryer will not come on, sometimes if you unplug it from the wall for an hour or two it will come on, but here recently..nothing, its pretty bad i mean i spend the money on the more expensive washer and dryer and they boyh are ****, the 1100.00 washer crapped out after 3 years and no support from whirlpool, i will never buy from whirlpool again....
  • tommyg16 Apr 14, 2008
    If the light bulb burns out will it shut down the board?
  • Bodasious Apr 24, 2008
    We have a light on inside. Have replaced electronic control board and still have no LEDs. Our model # has a QO at the end if this means anythiing
    Scholar:
  • 76 Answers
Slats Does display shows anything? Does any indicator light on the control panel lights up? When you open the door did you see the light comes on? If nothing happens, there is a problem with the power source from the outlet or the power cord not connected properly (possible burned out wires) to the dryer. If you see the light inside the dryer, then the problem is a bad control board. Let me know and do not place a new question. Just put a comment and I'll get e-mail notification. Gendos...post back
Posted on Mar 03, 2007
  • Gennadiy Kagan Mar 04, 2007
    slats
    I still believe the problem is the power source. How did you measure the power from the outlet? It's supposed to be 120V between each hot leg and neutral, and 240V between two hot legs. Let me know what you find.
    Gendos
Electrolux dryer EWMED65HSS isn't starting- There isn't any noise when I turn the knobs- display panel does initial light up but nothing shows on it. Any suggestions? Already checked power cord
Check your power supply/plug in outlet for proper voltage, e.g. 240 volts or 120 volts on portable dryers first. if that checks out, the next thing to check is the door switch, followed by the thermal limiter. Always disconnect power from its source before attempting diagnosis or disassembly.
This link can help if you need to go beyond that.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 25, 2017 | Electrolux Dryers
Model #KEYS850GGQ0. dryer made bit of groaning noise on start up. Repeat next 4-5 starts, then would not start. Timer is ticking. Fiddled some with door switch. No help. Suggestions? Thank you, K C
Go to www.repairclinic.com and enter KEYS850GGQ0. With luck, you will be presented with a list of common replacement parts and may be able to view a generic disassembly video which will help you locate the source of the noise.
Jan 22, 2017 | Dryers
Model # fex831fso stackable frigidaire dryer wont start just humms
you may have applied high voltage/power or in appropiet current flowing through the conductors
Feb 16, 2016 | Frigidaire Washing Machines
Why does my dryer will complete a cycle then shut off. It then goes to the next setting an starts by its self. Any suggestions?
control board defective? bad moister sensor not sensing dry clothes and going into dry cycle agin?
Jun 21, 2014 | Samsung DV337 Electric Dryer
Dryer was running put next load in will not start has power to dyer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 21, 2011 | Dryers
Have a PYE2300AY dryer power to timer
If you have power at the outlet and none at the door switch, check the thermal fuse. It should be behind the drum on the heater housing. It should have continuity through it. If it doesn't, it won't run.
May 02, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Apr 18, 2009 | Whirlpool ET8CHEXSQ Dryer
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Jul 25, 2008 | Whirlpool GEW9200L Electric Dryer
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool GEW9868K Electric Dryer Logo
209 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
