Question about Sony PlayStation 2 (PS2) Console
None of my disk will load - Sony PlayStation 2 (PS2) Console
  • 275 Answers
Try using a lens cleaner and then try your games and see if that works
Posted on Dec 11, 2008
None of the games will load,it says ''disk cannot be read,go to wii manual for troubleshooting''. i dont have a manual.
I have had that same problem with a game of mine. I believe that something may have gotten on the disk. Try to clean the disk and then try again. If it still won't work, you probably need to replace it.
Aug 05, 2011 | Nintendo Wii Console
Failure to boot. media test failure, operating system not found. how can I rectify this problem
Your computer tries to read from several devices, to try to load a copy of Windows:
* CD/DVD drive
* your disk-drive
* via your network-adapter, to communicate with a "boot-server" on the network
* 3.5-inch diskette
Your computer has tried each of the above devices, and found that NONE of them, including your disk-drive, contain an Operating System.
Either:
* your disk-drive is getting no power from your computer
* the "data" cable for the disk-drive is not connected to both the disk-drive and the motherboard
* the disk-drive is not spinning (dead motor)
* the electronics on the circuit-board under the "spinning" part of the disk-drive have failed.
Check the power/data cables. You may need to replace the disk-drive, and reinstall Windows.
Mar 18, 2011 | Computers & Internet
Hello .. I have a laptop and the 7520G Aceraspire HDDWD2500BEVS .. Disc HDD does not occur in the BIOS says it NONE .. .. I do not know how to reinstall from the CD, when the disc does not load .....
> HDD does not occur in the BIOS ... says it NONE
This is the first problem that you need to fix, before doing anything else.
Check that the disk-drive is properly "connected" (both "data" and "power" connections).
Enter "BIOS SETUP", and see if the disk-drive is correctly "detected".
Probably, you need to replace the disk-drive, and then reinstall Windows.
Is the current disk-drive still under the manufacturer's warranty?
Dec 22, 2010 | Western Digital WD2500BEVSRTL Scorpio...
Honda Odyssey 2006 DVD player says loading, disk in light on, and
pulled the fuse and left it out for over an hour. The system reset itself when turn back on.
Nov 06, 2009 | 2006 Honda Odyssey
Latitude C840 wont reconize optical drive and hard drive in BIOS, had loaded xp on hd did update to sp3 came back to see the progress the laptop had rebooted then the problem came up, tried two other hds...
For the hard drive you might have to go to computer and right click, then go to manage, then disk manage, then rescan disk if not just refresh it. The optical drive would have to be to go through the device manager in the system settings in the control panel and update the drivers.
May 18, 2009 | Dell Latitude C840 24X CD-R W/ DVD Combo...
MY DVD/CD DRIVE DOES NOT WORK IT WILL NOT READ THE DISC cannot play dvd,cds or load or make dvds or cds
Open the drawer.
Insert a disk, rotating the disk so that the writing on the face of the disk is "level".
(Imagine a clock-face on the disk; rotate the disk to make the writing go from "9" to "3",
not "10" to "4", nor "12" to "6".)
Close the drawer.
Wait a minute (to see if the disk should automatically start spinning).
Hold down the "Windows-flag" key on your keyboard, and touch (once) the 'E' key.
Wait a few seconds.
Open the drawer.
Is the disk still at the "9-to-3" position?
If so, then the CD-drive has *NOT* read the disk at all, and it needs to be replaced.
Try the above with the same disk in another computer, to see how it _should_ work.
Then, shutdown your computer.
Turn it on.
Look for the message: "Press DEL to enter setup".
Quickly, press the DEL key.
When you see the "setup" menu, press ENTER.
You should see at least 4 similar lines:
AUTO ... AUTO
AUTO ... AUTO
AUTO ... AUTO
AUTO ... AUTO
If you see 'NONE' anywhere, press the TAB key (or the DOWN-arrow key) until that 'NONE' is highlighted, and press PG-UP/PG-DOWN until it changes to AUTO.
Repeat for each 'NONE'.
Press ESC once to return to the "main-menu".
Press RIGHT-arrow and DOWN-arrow to highlight the "Detect Drives".
Press ENTER.
It should auto-detect your CD-drive, within 1 minute.
When it's finished detecting, press ESC.
Use the "arrow" keys to select 'SAVE CHANGES'.
Select it, and save the changes.
Let it reboot.
Now, is your CD-drive working?
Within Windows, hold-down the "Windows" key, and (once) touch the 'E' key.
Do you see an icon for the CD-drive?
If not, then the CD-drive is *NOT* physically-connected (either ribbon-cable or power-cable) to your computer's motherboard.
Apr 22, 2009 | Toshiba (WMD070AC) Magneto-Optical Disk...
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
Since update 2.0 ps3 will not load any disks
You need to call 1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
-Rel
Apr 18, 2008 | Sony Playstation 3 (PS3) Console
Does not load Win98se
Robb4. Use fdisk to make active partition and reformat.
Jan 25, 2008 | IBM ThinkPad T20 2647 Notebook
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
