Question about Lite On Computers & Internet
Its a new computer when i put dvd in the dvd runs up fast but will not reed
  • Gav Shaw May 11, 2010
    What type of Disc are you trying to Open? is it an Original or CD-R / DVD-R etc?
    Scholar:
  • 86 Answers
Does it read but just won't play the video?
If it won't play the dvd video, download: http://www.videolan.org/vlc/
If it won't read disc then download and run DMA Reset:
http://svp.co.uk/helpdesk/index.php?_m=downloads&_a=viewdownload&downloaditemid=15&nav=0
Let us know if this helps...
Posted on Dec 11, 2008
Tip
How to convert,Rip DVD onto HTC Evo 4G fast and simple ?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you wish to get DVD movie onto htc evo 4g, you’ll need DVD to HTC EVO converter to convert/rip DVD to mpeg-4 format that HTC Evo 4G accepts. please read step by step guide below on how to convert/rip DVD to HTC Evo 4G on Windows 7, Vista and Windows XP. Get either home video DVD or commercial DVD onto Evo 4G can be simple and fast using this powerful DVD to HTC EVO ripper/decrypter, and you will feel satisfied with the best original quality viewing with the 4.2 inch screen.
Software you need:
DVD to HTC Evo 4G encoder can re-encode DVD to HTC Evo 4G MPEG-4 format for smooth playback, and select DVD title, chapter to convert, and cut, join DVD scene as you wish then put DVD onto EVO. the program can run on Windows 7, Windows Vista, and Windows XP. DVD to HTC Evo 4G ripper can also extract audio from DVD and then convert to AAC, MP3 audio .
Step 1. Install and Run DVD to HTC Evo 4G Ripper for Windows
To install it, simply download HTC DVD Ripper.exe file onto your computer hard drive or desktop first.
on Jun 14, 2010 | Cell Phones
My blaster runs good but once it gets hot it revs up and wont stop i cant stop it with the run switch or the key i block the air to turn it off i put a new plug in it it has the oil pump off i mix the gas...
Sounds like an air leak... either at the base gasket or the reed valve gasket. or the carb/reed intake boot...MAYBE THE HEAD GASKET...
...AND ... get a qualified pro to look at your carb..tell him which parts you replaced...
Aug 06, 2017 | Yamaha 2004 Blaster Base
Computer display not wrking on Image 17.5s
please adjust the Reed switch see the diagram, clean it the reed, and tight very well the plugs and clean it.
2) replace new batteries with the same type, and polarity
3)clean the terminal contacts battery with c. cleaner, and try again.
if the problem persist RUN the software calibration, go under the hood motor and see the instruction or your instr. manual for troubleshooting.
God bless you
Nov 11, 2012 | Exercise & Fitness
Small pinholes in the reed valves
Yes mate... It is hard to say without seeing the reed valve but I guaranty a dodgy reed valve will make running and tuning the bike a nightmare. Your reeds need to seal perfectly and open and close about 2-3 times a second so if any cracks, holes or damage to them then they will never seal correctly which will allow blow back through the carbi and incorrect air and fuel mix to be sucked into the motor. best solution buy a V force reed kit it replaces the entire cage and reeds just bolts in (4 bolts) I sell them for about $160 delivered, or if your know what you are doing then you can just replace the reed petals with new... About $60 ishwww.motoxpartsonline.com
Feb 21, 2012 | 2004 Yamaha YZ 125
Will not read DVD
if cleaning the laser dosent fix the problem you can use a computer dvd rom drive to replace the original one.
May 20, 2010 | Apex Digital AD-500 DVD Player
Kx 125 reed valves
The reed valve assembly should hold solvent withot leaking. Remove for test. Disassemble and clean reeds and reed seat. Perfect seal is very important.
Good luck,
Techjoel
May 17, 2009 | 2003 kawasaki KX 125
I need a program to reed my DVD in my computer
I HAVE PROBLEM KINDLY HELP ME THAT HOW CAN MY COMPUTER READ THIS DVD?
Jan 29, 2009 | Canon DC210 DVD Camcorder
My dvd-rw drive e is not working i put a cd in is not reeding
1st try to CLEAN dvd lenses. buy a cleaning dvd or cd.
Nov 29, 2008 | HP Computers & Internet
Computers & Internet Logo
91 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
