Question about Bosch SHU9915UC Dishwasher
No water in dishwasher
I have a Bosch Dishwasher SHU9915. No water will enter the dishwasher I have replaced the water valve and still no luck. What is the next step. There are no water flow issues.
  • Anonymous Mar 13, 2014
    dishwasher is not pumping the water out
  • Anonymous Mar 22, 2014
    replacing reed switch flow sensor on bosch exxcel dishwaser
    Novelist:
  • 116 Answers
You need the check the water level switch which is located on the diaphram of the water fill assembly. This is located on the laft side of your machine behind the metal panel. if this switch sticks it will not allow water into the machine
Posted on Mar 11, 2007
Hi, just use cleaning liquid designed for diahwashers and ur float will come unstuck. Mine is totally gunked up inside the tubing (calcium Carbonate crytals and fungus. WHat does the diaphragm do? Tomas
Posted on Apr 10, 2007
  • Thomas Kessler Apr 10, 2007
    great, I just had exactly this problem on a similar bosch maschiine and used wd40 to resolve. I think I will need to get a new switch though. I do not trust it.
    Where can I get 1 from?
I have a SHU9922UC and the control panel has just died for the third time in 10 months. Its symptom is a dishwasher that runs and runs but never fills. I was told that this is an issue with this model. When they pull the control panel you can see a "burnt" area on the board. at $150 a repair, I'm getting a new dishwasher. It works great until the control panel wigs out.
Posted on Apr 06, 2007
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
AQUA SENSOR BOSCH DISHWASHER NOT FILLING WITH WATER
Hi, if your dishwasher is not filling with water, check the Water-inlet Valve and Float Switch
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 21, 2011 | Bosch Dishwashers
Hi my bosch washing machine is leaking water from underneath, in fact when you turn the water tap on, it sounds like it is filling up, but the machine is not even plugged in.
Welcome to FixYa.
Based on your description, " machine is leaking water from underneath... it sounds like it is filling up, but the machine is not even plugged in "... the issue is likely with the inlet/water valve.
**To remedy this you will need to replace the valve, not surprising for Bosch unfortunately**
This is what to look for..i.e.
As long as your model number is indeed SHU9915 series, this info below will be accurate.
I say not surprising because this part has been an issue for the B/S/H/ built machines in the past and as a result the original part number 189553 now substitutes to 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it is pretty straight forward. Here`s how...
1) undo the water line.
2) the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Nov 08, 2010 | Bosch SHU9915UC Dishwasher
No water going into never used bosch shu9915 dishwasher
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 27, 2010 | Bosch SHU9915UC Dishwasher
No water enters the dishwasher when its turned on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
May 23, 2010 | Bosch SHV46C03 Built-in Dishwasher
My dishwasher (bosch) is not taking in water. Can you help
heatman101
May 13, 2010 | Dishwashers
Not getting water into machine although mains water is reaching hose intake. model number of bosch is sgs44e28eu05 type si1501b
There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. thanks.
Feb 17, 2010 | Bosch Dishwashers
Bosch SHU9915 Does Not Drain
faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Mar 09, 2008 | Bosch SHU9950 Dishwasher
Power fine, but no water filling the tub
difficult not seeing the valve firsthand but if you could connect a tester to the solonoid and confirm that there is power on the terminals, then you know there is an issue with the valve. typically, if you have a leak, it to will raise the float and shut off the valve.
Oct 05, 2007 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch 4302 dishwasher
Water supply to the dishwasher is done through an electromagnet valve,located at the pipe's enterance to the machine. Test that it get power (with a multi- meter). In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck
May 24, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU9915UC Dishwasher Logo
1,178 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
