Question about MTX 4004 Car Audio Amplifier
Car amp problem
I have a mtx thunder8302 amp that is having a problem with the outputs. amp turns on fine but when i hook the sub up to it, all it does is suck the speaker in and the is no sound. what could cause this?
Re: car amp problem
Could be a Zener diode in the amps driver circuit which drives the sub one direction or another.
Posted on Apr 06, 2007
  • 218 Answers
Re: car amp problem
Probably a fried amp if your imput signal is OK. Good luck.
Posted on Mar 05, 2007
0 characters
3 Points
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
Brutus amp output problem
must be a bad amp..have you tried bridging them maybe youre channels are out it happens even if its brand new...factory deffects
Feb 21, 2010 | Hifonics Brutus BX 1605D Car Audio...
Mtx 1000xd led light is flashing and the subs will not work
The light flashing usually means there is a short somewhere. Check your wires to make sure there are no slices and are touching. Also check to make sure you have your remote wire hooked up.
Sep 19, 2009 | MTX X Thunder 1000XD Car Amp
Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Jul 12, 2008 | MTX 6001 Car Audio Amplifier
MTX 4501 Mono Amp - no output
It sounds like you have a defective switch or a broken solder connection. If the amp is new, return it for repair/replacement. Don't break the warranty seal if it has a warranty.
Apr 03, 2008 | Car Amplifiers
Mtx 895 trouble
check your fuse up front first. some amps will turn the light on with only the remote wire (the 12 volt signal from the head unit). That may be your issue. If not you need to check your signal input. try hooking the rca's to a diffrent source, i.e. other radio your tv anything with Rca out put. If still you get nothing then pull your subs out and take a regular 9 volt battery and touch the leads to the positive and negative of the sub. Just for a moment though if the subs move when they come in contact with the charge from the battery then my last suggestion would be to take it to a store where you can have an authorized tech check out the equiptment. Good luck
Nov 19, 2007 | MTX Thunder 895 Car Audio Amplifier
My amp has current on the subs output,when i try to hook up my subs it sparks every time. What can be the cause of that help me please.
Are you trying to hook up the subs while it's running? If so a spark would be expected because that's a lot of voltage... (and not a good idea). If you mean when the amps OFF, then the output is shorted to the power supply and the amp is in serious need of repair.
Sep 22, 2007 | MTX Thunder 404 Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
Help! Amp not turning on
Im sorry to have to inform you my friend, if you saw smoke, you burned one or more of the resistors or output devices inside the amp. Without a service manual, it will be a hard call on what exactly cooked. In alot of cases please forgive me for saying so, but the ampis not worth taking into a repair shop to be repaired, because of the high cost these days of labor. Its too bad there are no user replacable parts inside of these amps. Good Luck. Ps Please do not forget to rate this thread?
Oct 16, 2006 | MTX Thunder 421D Car Audio Amplifier
MTX 4004 Car Audio Amplifier Logo
73 people viewed this question
Top MTX Car Amplifiers Experts
Matthew Spark
Matthew Spark
Larry Spears
Larry Spears
Are you a MTX Car Amplifier Expert? Answer questions, earn points and help others
