Question about Olympus FE-140 Digital Camera
Olympus vg 140 battery problems - Olympus FE-140 Digital Camera
3 Suggested Answers
SOURCE:
  • 919 Answers
SOURCE: Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Posted on Jan 13, 2009
t00nz
  • 4738 Answers
SOURCE: dropped my brand new olympus VG-140 on the ground
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Posted on Nov 20, 2011
How can i fix my OLYMPUS 170 DIGICAM. It won't open and won't work also
See page 12. Using the computer it can take up to 10 hours to charge. I would remove the battery and charge in a separate charger. The Olympus cameras have been exceptionable for me. In the over 110K photos I have taken with mind I have gone through several batteries.
http://www.olympusamerica.com/files/oima_cckb/VG-170_MANUAL_EN.pdf
Caution it suggests not taking pictures with the AC adapter connected. However it says you can review.
Hope this has helped?
Jan 13, 2016 | Olympus Cameras
I have an Olympus VG-120. How do I physically update the firmware on my Olympus VG-120 camera? Thanks.
Do you have your user guide or owner's manual? Read that thoroughly and you will have no problems. If you don't, get one from the manufacturer - search their website and download.
Nov 06, 2015 | Olympus Cameras
Were can i download a setup cd rom for a olympus digital camera vg-140
Via this link, you not only can download the software you need (drivers and programs for different operating systems) but you also can get the manual and other support.
Product Support
Feb 25, 2015 | Olympus Cameras
Memorary card with write protect
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 10, 2013 | Olympus Vg-140 14.0-megapixel Digital...
My Olympus VG120 won't turn on. fast indicator lamp
1) change the batteries by new ones or recharge well the batteries
2) must be shure to use the o.k batteries type
3) clean the contacts batteries with contacts cleaner
4) poor contact between the cover camer and batteries contacts adjust it, and clean it
5) Wrong polarities with batteries inside.
6) memor card/slot/battery cover open
Jul 31, 2012 | Olympus Vg-120 14mp Digital Camera Silver...
Olympus camera got wet
Yes, there is hope. remove everything you can from it and leave all of the access panels open and then leave it in a warm dry place for a couple of days or a week. The problem is that you have turned it on, this means that there is a very real possibility that you have shorted something inside. Good luck.
May 12, 2012 | Olympus Vg-140 14.0-megapixel Digital...
Dropped my brand new olympus VG-140 on the ground and now the zoom lens wont retract back into the camera. Indicator lamp flashes when on then turns off. Is this fixable?
Nov 07, 2011 | Olympus FE-140 Digital Camera
My camera was on, it was low battery but was still using it, then it turned off and the lens was still open, and everything else. I Put it in charge and it still wont turn on and the lens wont close. Its...
ive got a vg 120/d-705 olympus digital camera.reg it to the computer.says leave it plugged in for 3 hours which i have done and no movement in the camera now.is it working or not or do i take it back to the shop where i bought it from.please help me.
Sep 01, 2011 | Olympus Software VG-120 Digital Camera
Olympus FE-140 Digital Camera Logo
235 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
