Question about Philips 44PL9523 44 in. Rear Projection HDTV-Ready Television
Streaking inside of screen
After cleaning the screen on my TV according to the Manual I have recently noticed there is some streaking on the INSIDE near the bottom right corner of the screen. It is visible only when there is bright ambient light, but I would still like to get rid of it. Is it possible to remove the front screen in order to clean this streaking?
  • moonman50 Apr 09, 2008
    I have same problem. It started off when purchased 3 years ago having a small smudge and streak inside the screen panel. Now there are numerous smudges and streaks. Walking past the set while turned off, it looks absolutely filthy. Anyone have detailed instructions on removing the screen and cleaning it? I appreciate any help. Thanks.
  • hazeldun Jun 13, 2008
    streaking inside screen toshiba 32 " tv
    President:
  • 1,284 Answers
Philips screens tend to be very tough to remove as if you are not careful on removal of the screen frame bolts then the whole screen will come falling off.
Posted on Mar 19, 2007
SOURCE:
Streaks on copies
Run the printers maintenance software and run the align print head option and the run the clean print head option and check again and see if the streaking is still occurring.
Apr 10, 2014 | Canon imageRUNNER 2200
While Mitsubishi is off, have spots between inter-projector screen and outer
yes you can disassemble the front screen assembly to clean any spots dont use windex or streaking will result just a damp soft cloth then dry
Jan 02, 2013 | Mitsubishi WD-57733 57" HDTV
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
Instructions and cautions cleaning inside a Toshiba 50H13 I live in Arizona and dust gets everywhere. I think the DLP mirrors and inside the screen are dusty.
Indeed be careful cleaning those mirrors! try a very lightly dampened Q-Tip swab to clean them and dry them immediately with the other end of the swab to avoid any streaking.
Same process for the screen, except with a lint free cloth.
Jul 18, 2011 | Televison & Video
Ricoh Aficio 3800C: How do you clean the Development Unit Hello, I have a Ricoh Aficio 3800C. I noticed that there are faint Cyan streaks when I print. I opened up the printer/copier unit and looked at...
I believe what you are referring to is the drum inside the toner cartridge. The drums are usually very strong colors, blue or green and if it is streaking then the drum cleaning blade has failed on the inside and you need to replace the cartridge.
Feb 14, 2011 | Ricoh Aficio AP3800C Laser Printer
Sprayed windex on lcd tv screen. how to get rid of streaks on the screen?
You need to get LCD screen cleaner to keep from streaking the screen. Check with a computer store or an appliance store that sells LCD screens and they can recommend the correct method for cleaning the screen.
Dec 07, 2010 | Televison & Video
Cleaned mirrors and now everything is streaking
You need to clean all the "widows" inside the laser unit too. Cleaning only the mirrors will not do any good. You can use some Methylated Spirits to clean it propperly.
May 19, 2009 | HP Color LaserJet 2600n Printer
Streaking
Replace toner cartridge . Must be originals
Jun 17, 2008 | Dell 3010cn Laser Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
Streaking in view finder
The problem you are having is the bad ccd board . It is covered underr a recall notice from NIKON .
Just send it in
Feb 06, 2008 | Nikon Coolpix 5700 Digital Camera
Philips 44PL9523 44 in. Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
