Question about Roper REX4634KQ Electric Dryer
Dryer won't start when pushing the start button
A few weeks ago my dryer started acting up. I would have to push the start button 2-3 times before it would finally start running and stay on. Now it won't start at all. When I push the start button it just makes a zzzzzzz sound like its stuck and won't start.
  • 5 more comments
  • billie lewis Mar 03, 2007
    Also forgot to add it has been taking longer than normal to dry the clothes. I possibly thought that may be due to the moisture in our basement since its winter?
  • rick123x Feb 15, 2008
    push start dryer don't come on was working fine i can hear a buzz
  • JIMGREEN Mar 17, 2008
    DRYER WOULD RUN AND NOT STOP UNTIL U STOP IT MANUALLY
    FEW DAYS AGO IT WONT START
  • Anonymous Aug 20, 2008
    same exact discription
  • Anonymous Sep 21, 2008
    I just dried 2 separate loads and now it won't start at all. No buzzing noise. Just won't start when you push the button.
  • Anonymous Feb 04, 2009
    plugged in dryer and it doesnt start what should i do?
  • ed kingsbury May 11, 2010
    Mine is Model # Red44408QO but makes that same soft zzzzz sound but doesn't start. Is the motor the thing on the right top panel? Where do I find a new one?
    Scholar:
  • 76 Answers
Bjsouth Most likely the problem with your dryer is bad motor. It is not repairable and has to be replaced. If you feel you can do it yourself, let me know and I'll help to buy new motor and provide you with instructions how to replace it. Gendos...post back
Posted on Mar 04, 2007
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
Gas dryer will not start. Model MGDB850WR0 maytag bravo gas dryer serial MY3101043 purchased 2009. lights and display come on, push buttons give tones, but nothing happens when you push start. Display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Maytag Dryers
When I press the button to start the dryer it just makes the noise but doesn't kick on. The light was off a few weeks ago and i never got around to change the bulb. But I did pull the dryer out to clean...
I believe the light and the fact that it is not running are unrelated.
The light may simply have come loose and needs refitted or may need to be replaced. I'll need the model number of the dryer to help you further on this.
For the noise, try this (you may need two people):
1. Open the dryer door and locate the door switch. While pushing the door switch in, have someone else push the start button. 2. You'll hear the noise. Keep pushing both buttons and take your other hand, reach in side and grab one of the drum fins and manually push the drum in a clockwise direction. 3. The drum may take off on its own. BE CAREFUL TO REMOVE TO HAND QUICKLY TO NOT GET BUMPED BY THE FINS AS THEY BEGING TO ROTATE.
If it does not start, the motor needs to be replaced.
If this works, turn the dryer off, close the door and try to start it again just by pushing the start button. If it works, it may have been something obstructing the drum from turning. OR, the motor could be going out. It may continue to start on its own for an unkown period of time, a day, a week, and year. But eventually it will go out and will need replaced.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it. I'd need the model number to go any further.
Most dryers, however, have a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are Amana certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide.
Best, G
Aug 03, 2010 | Amana Dryers
Dryer will not start
A dryer will not run because: belt broken, faulty timer, faulty door switch, failed start capacitor in the motor.
There are other reasons, here are a few for you to check out.
Jan 04, 2010 | Kenmore 63942 Dryer
My Kenmore gas dryer stopped in the middle of the time. When I pushed the start button, it buzzed, but the dryer didn't start. I waited to make sure the dryer hadn't overheated, and then I pushed the start...
sounds like the mtor over heated and stalled out . it will do it again . best to delint motor this will help to keeeep it cool and may prevent a lint fire . mm
Dec 03, 2009 | Dryers
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Dryer does not run
The time my electric dryer acted like that, it turned out my door switch had gone bad.
Jan 22, 2009 | GE Profile Harmony DPGT750EC Electric...
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
1,450 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
