Question about Teac AG-D8900 Receiver
Resistors smoking and burning out on ht line
Hi i have a marshall jcm2000 tsl60,it turns on but when u flick the standby switch on r32 10k 1w started smoking then r64 1k 1w,both on the ht line.ive replaced these resistors plus the capacitors around it but still the same fault.any ideas?
    Problem Solver:
  • 6 Answers
To be passing enough current to burn the powerrail resistors there is clearly a short to earth from the HT line. Given the circuit of that amp, unless there is physical damage to internal wiring causing the problem, the most likely cause of the problem is one of the ECC83 preamp valves failing with an internal anode to cathode short. Have the valves tested or if there is nowhere local test them yourself with a resistance meter. Check pins 1 to 3 and 6 to 8. There should be no connection in a good valve. Its also worth checking there is no continuity between the heater filament and these pins (heater is pins 4,5 and 9). If you find a fault then discard the valve and buy a new one, repair the dead resistors and try the amp again.
Posted on Jul 18, 2009
Marshall jcm2000 tsl combo turns on but no sound from any channel
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
Sep 04, 2014 | Marshall Amplification Music
After a gig last night we tried our Marshall JCM 2000 DSL401and it had developed two noises without anything plugged in. The first is a transformer hum that I'd never noticed before and when standby is...
Likely the filter capacitors have a problem. Best to take this in for repair... it is ODD that there is noise with the standby switch is in standby... That makes no sense... In standby it appears that power is removed from the power amp high voltage so nothing should come through the speaker... Unles maybe one off the power tubes had a total meltdown which should have blown the fuse.
Sep 10, 2011 | Marshall Amplification Marshall Cover For...
My Marshall 4502E Amp switches on fine. However when you flick the STANDBY switch on it blows the 1.3A Fuse every time. Any solutions, baring in mind I have checked all the diodes, resisitors, rectifiers...
I would first check the filter electrolytic caps for shorts...
This is the WAY you work on this problem. Replace the fuse and put a 60 or 100 Watt incandescent lamp in series with the HOT power wire. This acts as a current limiter/automatic resetting fuse and you can search out where the current is going. Old trick we have used for more than 50 years. Also using a Variac to control the voltage can be useful, but the lamp should get you through the problem...
Feb 10, 2011 | Marshall Amplification Marshall MG250DFX...
The problem with my marshall ma100h amp is that out of the box brand new it stopped working within a few days. Earlier I turned on the amp power switch and let it warm up. About a minute later I kicked on...
Brand new? Take it for warranty repair IMMEDIATELY... don't mess with it !!!
The only thing for you to check is that you did not turn on "STANDBY" as this shuts down the power amp and the capacitors will bleed off and sound will fade. Try switch in both states before complaining
ONLY use the amp in STANDBY for a brief period (20 seconds) to let the tubes warm up... Leaving in STANDBY for a long period straains the input filter capacitor. If you are done with using the amp, turn it off...
Jan 14, 2011 | Marshall Amplification Marshall MA100H and...
Yesterday, I accidentally switched off the powerstrip which my 100 Watt JCM2000 DSL is plugged into. I immediately turned it back on, without shutting off the power, and heard a "POP" I then tested the...
It is unlikely that your actions with the plug strip caused any permanent damage to your unit.
If you unit has a digital effects unit, probably the setting for that got disturbed and you need to reset it to your desired setting.
Jan 18, 2010 | Marshall Amplification Music
My problem is that the clean channel doesn't work. The OD1/OD2 channel works just fine but I'm not getting any sound out of the clean channel... any ideas?
Here is the schematic:http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf There are a few possibilities.The jack for the footswitch for channel changing JS1 might be faulty. Zener diodes 1 and/or 2 might be faulty. Switch 2 may be defective. TR1 might be defective. IC 4 or 5 might be defective.Start with the channel switching circuitry testing in the order I gave you. Check the actual clean channel circuitry to see if you actually have a clean channel anymore. Before you do any of this make sure you know enough about troubleshooting and have at least a good VOM and are familiar with safety procedures. The filter capacitors in this amp store enough charge to kill you. A cheat to partially discharge them without damaging the amp is to unplug it from the wall while it is hooked up to the speaker cab you are using while it is on at a very low volume with a guitar cord plugged in. Make sure you use exact replacement parts if you tackle this. They don't have to be from Marshall, they just have to be exact electronic equivalents from a quality manufacturer installed correctly. I would recommend that if you have no experience or are at all unsure of the repair to take it to a Marshall dealer to have it done. Please rate me if this helps.
Nov 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Replacing power amp valves for Marshall JCM2000 TSL122
Unless you have experience working on tube amplifiers and all the necessary test equipment you should spend the money and have this done by a qualified electronics technician who has experience particularly servicing tube amplifiers.
Nov 05, 2009 | Audio Players & Recorders
My marshall jcm2000 dsl50 will not power itself the mains lead is fine and none of the fuses are blown but it wont power i have only had it four months why is it doing this.
Check standby power supply,it stays on all the time main power is off and is subject to damage from transits from power company.Bad switch?
Sep 07, 2009 | Marshall Music
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
Flicking chanels by itself
It either has a sticking switch (usually caused by using cleaning solutions on the screen) or the power relay is faulty or the remote control is faulty.
Take the batteries out to check the remote.
Thanks guy9
Jul 05, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Teac AG-D8900 Receiver Logo
300 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
