Question about HP Compaq nx5000 Notebook
Compaq nx5000 - will not power up. DIsk spins, green lights for a second , then powers down to only yellow light. SOmetimes - seems after long periods of no use - -powers up and runs. Have sourced new battery - but problem persists whether on batt or mains supply Ideas please. Do not want to replace motherboard as has been advised unles...
  • 8 more comments
  • Anonymous Dec 21, 2008
    i have two laptops with the same problem??
  • fatihsevinc Jan 02, 2009
    Same problem about hp compaq nx5000. Notebook does not start. When pressing the power on button, its run 2-3 seconds. And than shut down itself. I bought a new battery. But i didnt solve this problem. Please help us ?? Note: also my ac adapter is working well. i tested...
  • farnsworth Jan 17, 2009
    Same problem - happens on battery or mains. Have rescued the data off the disk using a USB enclosure but am now without a laptop.
  • sherzy Jan 19, 2009
    I have had this problem on 2 NX5000's and 1 NC6000, and reading up on the internet, it seems to be a common fault on these models, and seems to lie with a track/dry joint on one of the IC's on the left-hand side of the motherboard. I found that if you press down firmly on the left-hand side of the keyboard, it will boot a few more times, but it will eventually give-up completely. The only way I've found is to replace the motherboard.
  • Anonymous Mar 05, 2009
    I had the same problem on my NX5000. Resoldering the connections on the Maxim chip solved it. Although it could have also been solved by completely disassembling the machine and putting it back together. In any case, my machine is back up has been working for a couple of days now.
  • santabanta7 Mar 31, 2009
    same as above wid my lappy..can any body tell how 2 resolve that prob ?
  • Ben L Apr 04, 2009
    mine does the same thing. Dont think it's motherboard. More likely hard drive or memory. I havent fixed mine, just bought a new laptop. Hope this helps
  • Steven Dolan Apr 29, 2009
    Same problem I know it is the motherboard. For all of you who cannot fix this then there is another way to get your nx5000 to work. Remove the screws for the button panel and keyboard then disconnect your display. If you now connect an external display you can use your pc again.
  • a fucking guest Jun 08, 2013
    i HAD the same problem . remove the battery and the ac power cable and hold the power button for 30 seconds . then reconnect the ac cable and turn on the laptop . now it should work . if it does not try again . (took me 2 times)
    typing this for the 7th ******* time .. ... remove the battery and disconnect the ac power cable . now hold the power button for 30 seconds and reconnect the ac cable . now turn on your laptop . now it should work . (took me 2 times becouse i turned it off to put the battery back in ,second time i put it in while it was on)
    New Friend:
Ok now typing this for the 8th time . what's wrong with this site ..
firt remove the battery and the ac power cable .. now hold the power button for 30 seconds . reconnect the power cable and you should be able to turn it back on .. i had to do i twice on my laptop becouse it turned it back off by holding the power button while it was starting up so i could put the battery back in .
anyway if it does not work the first time then just try it again
this is the first thing you should try and especialy if you don't know what your doing
Posted on Jun 08, 2013
Firstly disconnect the cable for screen from *********** board and connect your pc to an external monitor/ LCD and start your computer. If the computer now works then your computer screen cable has a faulty connection to its invertor card in the screen. Check the cable contact is loosen.
I had my compaq 5000 fixed by this processedure. Good luck
Posted on Oct 12, 2012
I just got my nx5000 up and running again. The memory needed to be reseated in the socket (got this tip of the HP site) All I did was open it up and reseat the ram - just took it out and put it back in again. Problem solved. I also took the opportunity to vacuum a little bit of dust out, but I don't think this was anything to do with the problem.
Get a copy of the service manual (Just google "hp service manual nx5000") it has easy instructions at how to get to the memory - it is just under the keyboard.
Hope this helps!
Posted on Jan 17, 2009
  • farnsworth Jan 28, 2009
    Ok... the memory thing worked temporarily, the true cause is as sherzy found - broken/dry joints around one of the components. The offending chip is on the bottom of the main board and is labelled maxim 1987. There is a long discussion of this at the HP Business Support Forum called nc6000 no startup.
    This may take a little bit of expert help to fix, but if you know the right people or are handy with the soldering iron (or hot air) it is well worth it. The work is fairly delicate - mine was done under a microscope with a very fine tipped soldering iron. After resoldering all the joints on the maxim 1987 chip my nx5000 is back up and running again and so far no more problems.
Janome Memory Craft 9000 slow to power on
it could be the power cord, or a computer part, it needs to be serviced
Mar 13, 2012 | Janome Memory Craft 9000 Computerized...
Compaq nx5000 PC Notebook: my compaq nx5000 is notpowering up when i power it...
First check to ensure the battery is properly seated. If it's in good, then this is probably a power supply issue or a problem with the motherboard.
May 06, 2010 | HP Compaq nx5000 Notebook
I have a compaq presario sr1503wm.There is a green light by the power button and a much smaller green light below that.Sometimes this light turns yellow.what is it?and whats it do?
this may be the battery light or Hard drive light.
Usually if the light is green then yellow this is an indicator of the low battery.
Mar 31, 2010 | Computers & Internet
Compaq nx5000 with new battery and new power
Dear,
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Problem turning on/keeping on computer
has the ram been upgraded?
sometimes the wrong ram will do that ,
if not, could be motherboard issue
Jul 19, 2009 | HP Compaq nx5000 Notebook
PS3 shut down during mid-game/now it will not eject the game disk
not a solution but a possible answer it is possibly the ylod (yellow light of death) it seems a few people are getting this and my ps3 has broke aswell even sony dont know what is wrong with it. but your problem sounds like the ylod
Jun 07, 2009 | Sony Playstation 3 (PS3) Console
Both USB ports suddenly don't work on my Campaq nx5000 notebook. I get power from both because the light under the mouse lights up. Any ideas what could be wrong? Thanks.
try to check the device manager.
by right clicking my computer, then hardware tab, device manager.
on the device manager check for the usb drivers if they are installed properly, if there is a problem you will see a yellow exclamation point on the usb.
try also to check for the updated drivers for the usb controllers on your laptop.
Sep 05, 2008 | HP Compaq nx5000 Notebook
Not working
remove the ram clean it put it back yor problem will solvs
Aug 04, 2008 | HP Compaq nx5000 Notebook
Power problem
The CPU might be overheating because its lose, try to fix it well also check all the other devices if they are firmly fixed.
Mar 06, 2008 | HP Compaq nx5000 Notebook
HP Compaq nx5000 Notebook Logo
2,096 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
