Zassenhaus Knee Mill Hand Crank 156 Manual Burr Grinder
Problem for Zassenhaus Knee Mill Hand Crank 156 Manual Burr Grinder
How do I de-scale my coffee maker?
By Ross - usenet poster
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
The coffee maker should be de-scaled every two months using a specifically designed product or 500ml of pure spirit vinegar. Do not forget to rinse the coffee maker (run clean water through the machine - as if making coffee, but without the grounds) once or twice before re-using.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 22, 2008
Not Rated)
lil_angel_92
Rank: Apprentice
Rating: 0%, 0 votes
i have a small badeeda bay and i dont know how to clean it properly. any suggestions?
i wash it trim it but its still filthy. my bf wont touch it and my dad and i got into a fight on how to measure it properly before 'use'
URGENT.
Was this helpful?
Yes
No
Solution #3
posted on Dec 18, 2007
Not Rated)
fifthgen
Rank: Apprentice
Rating: 100%, 1 votes
Citric acid solution. Citric acid is used for canning and is available cheaply from co-ops, and at some pharmacies. It is an ingredient in Koolaid as well and is food safe. Mix up 10 grams per liter of water rinse for at least three cycles. a pound costs $5.00 or so and will last you for life even if you own and use three coffee machines.
Was this helpful?
Yes
No
Popular Solutions for Zassenhaus Knee Mill Hand
Questions and Unsolved Problems for Zassenhaus Knee Mill Hand
Do you recommend Zassenhaus Knee Mill Hand Crank 156 Manual Burr Grinder?
Answer
Answer
blade turns very slowly and will not grind coffee beans. Wife, God love her, may have ground nuts... (More)
Answer
calibrate sm 90 coffee grinder burrs
Answer
calibration of burr setting for sm 90 burr coffee grinder
Answer
what grind setting number do you use for rocket espresso best grind
Answer
Dear Sir My Tv has a problem due to shirt cricuit i have loss STR c6706 or some transister so i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zassenhaus Knee Mill Hand...:
Top Coffee Grinder Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee Grinder Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
