Problem with Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
How hard is it to replace? 112'' belt x 1/2''?
216 people viewed this problem
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
Source: how to replace drive belt
Does the lever that engages the blades have pressure on or does it feel loose. It is possible that the linkage from the lever to the idler pulley has come off. Raise the hood and watch the lever as it is engaged and disengaged there shold be somekind of linkage moving a pulley in and out to tighten the belt so the blades will turn. hpope this helps
Source: I have a Husqvarna CTH 171. When i engage the blades they
hi I've oil getting into air filter,why is this happen?
Source: Need a new drive belt for a Husqvarna cth 130
I need to change the two drive belts on my Husqvarna LT112 garden tractor. My manual is in French and l need an English...
I replaced the drive belts on my MTD Tradesman model 139-652-118. Now it won't hardly shift and the break has to be...
I need a drive belt diagram for a 1974 john deere garden tractor 112 wiyh 12 hp kohler engine
46 in yardman model OEM-190-112 I need to know the belt pattern please
Kohler engine carburetor adjustment. My normal rule when I do not have more info for all air adjustment screws: Bottom,...
I just changed the drive belt on my Husquvarna yth2348. When I go to start the tractor it just keeps turning over...
I just noticed that the blades on my Husqvarna spin even though they are not engaged. This is my first lawn tractor so...
David Johnson try this link..Hope it helps and Merry Christmas!
May 11, 2010
