Question about Zenith Z27X22D 27" TV
Picture is dark
Zenith Z27X22D, picture is very dark, can hardly see menu box. Screen dark no matter what it is hooked up to, cable, local, vcr's.... Model is ten years old. Has the Tube gone bad? Is it worth fixing?
    President:
  • 1,284 Answers
The tube is bad and is very common on the Zeniths to show that symptom. They had a lot of bad CRT's back then.
Posted on Mar 05, 2007
    Novelist:
    Champion:
  • 275 Answers
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Posted on Mar 04, 2007
2 Suggested Answers
  • 40 Answers
SOURCE: picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Posted on Feb 15, 2008
I have sound but no picture. The screen is black
can you see any any menus or the volume bar or channel indicator?
Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
Dec 16, 2008 | Televison & Video
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Picture is dark
Feb 14, 2008 | Zenith C27A24T 27" TV
Zenith Z27X22D Service Menu Codes needed
significant vertical overscan. It is such that it's impossible to read crawls and such at the bottom of the screen. I think this problem is a tv problem. it is due to vertical section. please change electrolytic capacitor in vertical output section. it will be ok. it is common problem can be fixed at home & very simple.
Oct 03, 2007 | Zenith Z27X22D 27" TV
Service menu instructions needed
service menu code is 9876, i think. and you can manually adjust the focus using network54's post on "blurry z27x22d".
Sep 16, 2007 | Zenith Z27X22D 27" TV
Televison & Video Logo
129 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
