Question about HP LaserJet 1020 Printer
HP 1006 laser printer replace usb port
Printer was knocked off the desk by my cat. Now the printer port is loose and disconnected inside the printer housing. How do you remove the side of the case with all the controls? There's one screw for that side of the case and a tab that to keep it in place. I removed the screw but that side is still connected somehow... perhaps more hidden tabs. Cannot find a service manual online. Any help is appreciated. Thanks Frank
  • 479 Answers
U will have to open the sides of the printer first to remove that.the sides r connected through screws and internal locks which sometimes get breaks while opening be care full.after that back plaste will come out easily and from there u can check out that usb housing connection.
Posted on Dec 10, 2008
My HP Laserjet 1020 powers on but now it's not recognized by my computer anymore. What happened & how can I get it to reconnect?
The solution to this problem is as simple as disconnecting your printer, going into CONTROL PANEL / PRINTERS AND SCANNERS, right click on the icon for your laser printer, then select "remove." Once you have removed the printer in the Control Panel, plug the printer back into your USB port, power it on, and it should plug & play from there.
Jul 20, 2014 | HP LaserJet 1020 Printer
Problem with USB HP PSC 2210 printer connection
Is it under warranty?? call HP..They will replace it....
Its better to replace the usb port on the Printer as a whole.
Aug 25, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hooking up a Lexmark OPTRA E Printer to a Vista - USB Port
I do not believe that the Optra E is supported by Lexmark on Vista.
Not all products from the Optra family (if any) can meet the demands of that platform.
Feb 10, 2009 | Lexmark Optra E Plus Mac Ready Laser...
Hp printer will not print through the computer
Sometime USB PRT they reinstall a new PRT with a new usb port.
Check if you have a new entry w same prt name+ copy n inside your Control panel "Printer and faxes "applet.
Select the new Prt (with latest Copy N number) as Default printer and let me know if it's working.
Dec 28, 2008 | Office Equipment & Supplies
HP Desk Jet 842C printer - need cable
Hi Debbie,
You should be able to use this printer with a USB cable. You can pick up a USB cable just about anywhere that they sell computer or printer equipment. Just tell them you need a USB printer cable. This is a standard item and no further description is needed.
The Driver for this will probably be a native driver, and you probably wont have to download a new one, but just in case, here is the link for the driver directly from HP.
Good Luck
Oct 08, 2008 | HP DeskJet 842c InkJet Printer
Usb port
thats very simple friend, just go back to your system and search for a flat connector called usb with a symbol to make you identify it on the cable of the scanner and on the back of the system
Jun 28, 2008 | HP PhotoSmart C4280 Laser Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Mini USB disconnected inside HP all-in-one 2210v psc
You will have to take the printer apart and re-solder the usb connector to the board.
it was jerked out likely by moving the printer while it was attached to the cored or was tripped on.
it may not be an easy job to fix as you have to have several tools
and soldering skills,
you need a electronics nerd to help.
Feb 02, 2008 | Office Equipment & Supplies
HP 610 C inkjet printer
i have a laptop full of usb ports ,for that i have purchased parallel to usb port to suit to printer and laptop but iam unable to print .laptop is asking drivers
Nov 18, 2007 | HP DeskJet 610c InkJet Printer
HP LaserJet 1020 Printer Logo
153 people viewed this question
Ben Johnson
