Question about Hunter 30755 Air Purifier
Air purifier locked in one mode
Will not go into any other speed using panel buttons
Hold both fan speeds for 3 seconds to unlock panel.
Posted on Jan 25, 2009
My Brookstone PureIon Advanced air filter is stuck in TURBO mode and I cannot get it to slow down! how do I UN-stick it?
Sounds like the control is damaged. You could try calling Brookstone service and see what they say (they have a one-year warranty). Number is 1-800-292-9819.
Aug 12, 2016 | Brookstone Air Purifiers
My fresh air 2.1 won't go into away mode. I
Fresh Air purifiers are noted for two weak points. The display circuit board and the main circuit board. Call (336) 499-2505 and they will help you work through the problem. They give away information.
May 25, 2012 | Ecoquest Air Purifiers
Machine is very noisy especially on silent mode.
Check the fan bearing. Lubricate with spray grease on the spindle but be prepared to replace if no better.
Apr 05, 2012 | Oreck XL Professional Air Purifier
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
The fan speed only works on whisper mode. Low, turbo and high do not work!
It may be faulty switch or it could be a bad fan sensor. Most likely the problem is in the switch.
Jun 12, 2009 | Brookstone Pure-Ion (506840) Air Purifier
Lights won`t work,buttons on front and remote will not change the motor speed,stuck on low,ECO Quest Breeze AT.Thank you.
Did anybody solve this for you? The same thing happened to mine! All purifier lights come on but it's stuck on low!
Sep 18, 2008 | Ecoquest Breeze AT Living Air Purifier
Remote & buttons want work
HURRY - you are still within your warranty period. Call EcoQuest for support.
Jan 30, 2008 | Ecoquest Fresh Air Air Purifier
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Hunter 30755 Air Purifier Logo
    115 people viewed this question
    Top Hunter Air Purifiers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
