Question about Toshiba Satellite 2410-S203 Notebook
I cannot enter the bios setup of my laptop..
When i boot my laptop the POST is not appearing..
  • nas john
    nas john May 11, 2010
    please send us the model for your laptop forexample
Press 'esc'
Posted on Feb 11, 2009
How do i get my HP pavilion 521n to boot DVD ?
  • Press the "F1" or "F10" key when the logo appears on the screen to enter the BIOS setup.
  • Navigate to the BIOS menu "Advanced" using the right/left arrow keys on your keyboard.
  • Get to the option "Boot Order" with up/down arrow keys, and press "Enter."
  • Select the first boot device under the "Boot Order menu option and press "Enter."
  • Select "DVD" from the list of available boot devices and press "Enter."
  • Press the "F10" key to save your changes and exit the BIOS setup. The computer will automatically restart and then will boot from the DVD.
  • Aug 05, 2013 | Computers & Internet
    My laptop is not allowing me to install OS (windows) i suggest mayb its bios securities now how can i remove the security
    A) DO NOT post your email address. It's in the FixYa T.O.S.
    (Terms of Service)
    (Plus it's a worldwide forum. You are opening your email to all sorts of spam)
    B) Are you trying to install the SAME operating system?
    Example: Windows XP over Windows XP?
    Primer:
    Windows does not like to be written over. A type of security.
    It definitely does not like the SAME O/S being written over it.
    (Same version and build)
    Go to BIOS Setup, and to Boot Options.
    In Boot Options make sure CDROM is set as the first boot device.
    CDROM will be at the top of the list.
    SAVE changes.
    Your computer will now boot off of whatever is in the optical drive.
    Need laptop manufacturer name, and Model Number, to try to guide you in entering BIOS Setup.
    { OR,...as soon as you turn the laptop on look at the bottom of the monitor screen. Look for;
    A) enter Setup, or
    B) enter BIOS Setup, or
    C) enter CMOS Setup
    There will be a key on the Keyboard to press, that is stated next to the above. (Example: enter BIOS Setup/ Delete, or enter CMOS Setup/F2)
    Once you see the key, (Screen goes by very f-a-s-t), restart the computer.
    (Press the CTRL key, ALT key, and DELete key, AT THE SAME TIME, to restart the computer)
    As SOON as the computer restarts, start tapping on the key.
    (Tap in 2 second intervals. If you hear a beeping, ignore it.
    It is a Stuck Key Error Code )
    Post back with your findings in a Comment.
    Regards,
    joecoolvette
    Jan 29, 2012 | Computers & Internet
    Zenith director laptop, after switching on the system, press F2 for bios setup and F12 for boot setup screen appears and hangs up. What to do?
    If you need to boot your cd you not need to press F12 just after entering bios setting goto boot configuration and change your first boot device to cd\dvd and press F10 and select yes.
    Dec 08, 2010 | Computers & Internet
    I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
    Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
    Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
    Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
    Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
    I have a message manufacturing mode:level (67)
    Do the following with nothing attached other then the AC Power. After trying these fixes and neither works, it is a mother board issue. Replace the mother board.
    1. Enter System Setup (aka BIOS) reset it to its default settings. By doing the following:
    Sep 11, 2010 | Dell Latitude D610 Notebook
    What is the boot up sequence please
    You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
    Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
    Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
    Hope this helps!
    Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
    Entering bios setup
    Occasionally, most computer owners will need to access BIOS on their computers in order to change or update the computer's most basic operations; such as memory and boot order.
    Different computer manufacturers will have you press different buttons to access BIOS depending on the model you have. For example, on my laptop, I press F12 to enter the BIOS setup utility.
    Here's how to figure out how to enter your computers BIOS setup utility. 1
    Turn your computer on or shut it down and restart it if it is already on.
  • Step 2 As soon as the computer starts up, watch for a message that informs you about which button you will need to push in order to enter setup, aka BIOS.
  • Step 3 The opportunity to press the correct key to enter BIOS passes by quickly, so you need to find that key and press it before the computer moves on to the next stage of booting. If you miss your chance, just restart the computer and try again.
    You can always access BIOS, even on computers that dont have an operating system installed. This is because BIOS is part of your computer's motherboard hardware and has nothing to do with Windows, Linux or whatever operating system you may be using.
  • Dec 02, 2009 | Alienware PC Systems M7700 Notebook
    Bios password
    You will need the BIOS password to enter the BIOS setup.
    To do a hardware reset remove the CMOS batteries for 30 minutes. Once your BIOS password is removed, you will need to press the <F2> key during POST (Power On Self Test) to enter the Acer BIOS setup.
    After you enter BIOS, go to the Boot tab and down to "Security" and make your changes there.
    If you need help with the default password, please re-post your request.
    Thanks and good luck.
    Mar 19, 2009 | Aspire Acer 7520-5324 Laptop
    Server error
    The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
    02a2: BMC System Error Log (SEL) Full
    Press F1 to Continue, Press F2 to Setup
    If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
    1. Boot the server and press the F10 key when prompted to run BIOS Setup.
    2. Select the "Advanced" menu.
    3. Scroll down to "IPMI" and press the ENTER key
    4. Scroll down to the System Event Log and press the ENTER key.
    5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
    6. Select "Enable."
    7. Press the F10 key to Save the changes and exit the BIOS Setup.
    Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
    Unable to get to CMOS using any of the 3 methods
    This machine is one of the first "legacy free" models which means there are no BIOS options to change. All settings and resources must be assigned by the OS.
    For details, please check the "legacy free" FAQ on MS Knowledge base.
    If you are trying to access the BIOS to change boot order so that you can boot from a CD, hold down the 'c' key during POST/boot. This will case your laptop to boot from CD-ROM.
    Apr 09, 2008 | Toshiba Satellite 5005-S504 Notebook
    Toshiba Satellite 2410-S203 Notebook Logo
    137 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
