Question about Baby Capes The Polartec Fleece
Copy Im trying to make front and back copies on one paper, can anyone help me?
    Problem Solver:
  • 8 Answers
In printer preferences menu tab there is a checkbox for (print on both sides) it must be checked
Posted on Dec 29, 2008
I need to copy my license front n back of it on the same side of the paper how do i do it
Copy the front of your license on a piece of page. Take that piece of paper, put the back of the license facing up beside it and copy this page.
Good luck,
Paul
Jan 25, 2016 | Office Equipment & Supplies
My konica 2223 copy lamp is dim resulting to paper jams and blank copies, im just repalce my Power supply board
Check your newly installed power supply board input rating if the same with the old one if yes P51 error common for front door open and can be cleared by closing the front door. Door lock actually connect to the interlock switch at the back beside power supply unit sometimes we just clean connectors if not replace power supply. Now if the light scan with very low intensity the result would be darker and probably will cause you paper jam at the fusing/heater unit but, if blank copies the light intensity is to high. you may adjust or correct it by CVR adjustment/Light intensity adjustment " go to 36 mode off machine hold 3 and 6 while power on release 3&6 after display reads CC, enter address 9-0, start, p- select (0/30 darker 35/55 normal- 60/90 lighter) this adjustment may vary depending on drum coating and optical adjustment/cleaning. I suggest clean first all mirrors before you do it.Hope this may help you sold the problem.
Feb 19, 2012 | Office Equipment & Supplies
I AM TRYING TO FIND HOW TO COPY FRONT AND BACK PAGES.
copy the front page and when it prints, put the copy in the paper holder backwards and copy the back page. This new copy will have the front page and back page on the same sheet of paper.
Oct 07, 2010 | Canon imageRUNNER 2010F Copier
Printer paper jam
Do a printer check by copying on standalone. means placing a document inside the scanner. Load 10 sheets of regular paper into the feeder then press the start button to begin copying. Try 2 copies. If it gives you the same error, then there is already an issue with the gear inside the printer.
If your unit is not under warranty anymore, log on to support.epson.com. Click on help me find a service center to the right of the page. You will have to put in your zip code to find an epson certified servicer near to your area.
If your unit is not a year old yet, please call epson technical support.
If it copied successfully, it could be just the paper settings, or the type of paper that you are using is not supported or you might have to uninstall and re-install drivers.
May 06, 2009 | Epson Stylus RX580 InkJet Photo Printer
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
When turned on only copy button lit and a red exclamation lighton
Hi
Try unplugging it and check for specks of paper inside the printer, then try to replug it from outlet and turn it back on. try if it will copy then try printing. Hope this helps
Dec 12, 2008 | Epson Stylus RX500 All-In-One InkJet...
COPY
does your copier with duplex unit? if not only way you can do is by manual.
Dec 10, 2008 | Office Equipment & Supplies
Im back .. with same hp printer problem
take a look at the rollers that grabs the paper if its moving or looks like trying to grab paper. swabbing it helps.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
Image is rotated
Select the correct paper size by rotating the green paper size selector in front of the papertray.There is two selection for A4 paper.A4 lengthwise and breadthwise.select it correctly
Aug 21, 2007 | Ricoh Aficio 2020 All-In-One Laser Printer
Baby Gear Logo
83 people viewed this question
Top Baby Capes Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Capes Baby Gear Expert? Answer questions, earn points and help others
