Question about AT&T Blackberry Curve 8300 Smartphone
I am having a problem with texting on my Blackberry Curve. Everytime I try to text I get Uncaught Exemption:DSSMA:invalid state(5):3. How do I undo this, so I can text and recieve texts?
    Brigadier General:
  • 7,752 Answers
Try this method it works...
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows.
The good news, starting from scratch, you will be back in service in a couple of hours. I am having a problem - biggrin.gif
Note: Windows 7 beta is not compatible with these instructions.
1. ...
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch. This was the way all 'computers worked prior to Mcintosh and Windows.
Windows XP: Start / Run... / Command
Windows Vista: Start / Command (type this into 'start search')
Posted on Feb 06, 2010
What is DSSMA uncaught exception invalid state
This a common exception that was happening with blackberry curves. Here is what you do. Take the battery out. Next you take out the memory card. Next you plug your phone into the desktop. You will need to do a reset on your phone. Once you reset the phone. Stick the memory card and thee battery back into the phone. The blackberry desk top will reset your phone.Make sure you sync your phone numbers and contacts. After the reset your phone will resync your information. Be careful if during the sync and reset that the phone does not shut off
May 30, 2014 | RIM BlackBerry Curve 8520 Smartphone
I get the message Uncaught exception: DSSMA: invalid state (5):10060 everytime I try to get my messages
Hi, When the BlackBerry smartphone user attempts to access or open the messages folder from the Home screen, the Uncaught Exception: DSSMA Invalid state error message is displayed. To resolve this error, you need to perform a hard reset of the BlackBerry smartphone. If you face the same error even after performing a hard reset of the BlackBerry smartphone, you need to complete the following steps: 1. Back up the BlackBerry smartphone using BlackBerry Desktop Manager. Erase all data and applications from the BlackBerry smartphone. Restore the backup of the BlackBerry smartphone using BlackBerry Desktop Manager. Hope I helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | RIM BlackBerry 8800
Uncaught exception dssma invalid state (5) 6
Perform a hard reset of the BlackBerry smartphone.
1. Remove the Battery and Sim Card from your Handset and Re insert it.
If it's still the same problem.
Perform these steps : -
Take a Back Up of your Blackberry Smartphone.
Connect the BlackBerry device to the computer using a USB cable, and open the BlackBerry Desktop Manager.
Ensure that the BlackBerry device is connected correctly. The word Connected should be displayed at the bottom of the BlackBerry Desktop Manager screen.
Double-click on the Backup and Restore icon.
In the Backup and Restore screen, click Backup.
Choose a location where you wish to save your backup file.
Give the backup file a new name or leave the default name in the File Name field.
Click Save.
The BlackBerry device has now been fully backed up.
Back up will be in .ipd file format.
Then in your Handset perform these steps :-
1. Press Menu Key,
2.Select Option Icon in the Menu screen
3.Go to Security Options.
4.then Go to General settings
5.Press Menu key, you will get an option Wipe Handheld select it.
6.Type the password if you get a prompt, default Password "Blackberry"
7.you will get a confirmation message,Data will be Erased.
8.Click Continue.
9.It will start Wiping your Handheld.
10. Once Data is Erased,Handset will Automatically Restart.
To Restore the Data to your B Handheld
Double-click on the Restore Tab.
Navigate to the backup file you want to restore to your BlackBerry smartphone.
Double-click the backup (.ipd) file.
Oct 14, 2009 | RIM BlackBerry Pearl 8100
Uncaught exception DSSMA: invalid state (5):2
You first need to attempt a hard reset. Simply put, pull the battery while the phone is on,wait 30 seconds, then replace it and turn it on. If that doesn't work, make sure you have the latest version of Blackberry Desktop Manager downloaded to your computer, back up your phone using backup/restore, the delete all data and applications the do a restore using your previous back up. For full instructions go to www.blackberry.com/support and search KB10859.
Sep 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
When i click to text message, my black berry says DSSMA (5):15 invalid state how do i get back to texting...
try this method this should correct the issue you are having
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version. This is not supplied on your BlackBerry CD, Ref: 3 links to BlackBerry's download pages.
May 12, 2009 | AT&T Blackberry Curve 8300 Smartphone
Text messaging
turn the phone off and take the battery out then turn it back on and for some reason it re sets itself and works
Mar 06, 2008 | RIM BlackBerry Pearl 8100
AT&T Blackberry Curve 8300 Smartphone Logo
192 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
