Question about SanDisk Sansa e200 MP3 Player
Sansa m200 mp3. i have a mac.
The cd wont work in the disk drive so i can not download the program. i do not have windows. is there a way around this? Leigh
Leigh, what you need to do is to turn both your mac and your mp3 off. Then do the following in exactly this order: Plug in your mp3 to the mac. Then turn on the Mac. Then call your best friend, Hat boy. Then switch on the mp3. The little icon should pop up. If this doesn't happen, switch the mac off and on again. Once you have the icon up, click on this and this should solve most of your problems.
Posted on Jul 01, 2009
How can I put music on Sansa MP3 player from Macbook Pro?
Not to sure about a mac but I think mac's use a mp4 format when it rips a cd, and the Sansa will use a mp3 file. You can download a free program to convert these files but again, I know where for a PC but not a mac. Look for free mp4 to mp3 converter program for Mac..
Jan 28, 2010 | SanDisk Sansa m230 MP3 Player
I have a MAC and it will recognise the sandisk m240 mp3 player. When you look under the finder tab it is there. But when I try to download songs from i tunes it won't work. Any ideas?
Tranferring songs from iTunes to the m240 needs to be done in mp3 format. iTunes music in aac format should be converted to mp3.
Putting files in the mp3 format:
1. Using iTunes 7:
http://kb.sandisk.com/app/answers/detail/a_id/275
2. using iTunes 8:
http://kb.sandisk.com/app/answers/detail/a_id/1129
On next site follow the steps how to download mp3 files in iTunes proceeding from step 1:
http://kb.sandisk.com/app/answers/detail/a_id/1141/kw/itunes/r_id/101834
Manual for m200 series players:
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Need more help ? Just post a comment.
Jan 03, 2010 | SanDisk Sansa m240 MP3 Player
I can't download music to my San Disk 1GB MP3 player that I got for Christmas. I did not get a manual with it.
To put music on your Sansa e250 you will do this:
Download Windows Media Player 9 or 10 to your computer. I would use Media Player 10 as it is the newer player. After you download Media Player 9 or 10 open it up on your computer, and then hook up your mp3 player, it should be recognized by Media Player and then you can transfer the songs to it. You need to put the music cd in your computer cd player and download the songs to Media Player using Windows Media Player 9 or 10. I have also included a website where you can download the user manual, it will say e200, but the instructions are also for the e250. Good Luck, I hope this helps. Please rate me, Thank You.
Dec 30, 2009 | SanDisk Sansa Clip MP3 Player
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
My computer won't recognize my Sansa mp3 in order to download
If you have a main menu on your Sandisk Sansa player, Choose Settings, and make sure you have the correct USB setting selected.
If you Use Windows Media Player 10, choose auto-detect.
If you use Windows Media Player 9 or earlier, choose MSC.
Dec 27, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
I have a SanDisk Sansa m200 mp3 and a macbook pro
Even on a Macbook pro, you should be able to access your "my computer" option, where it shows you the local disk drives and everything. your mp3 player icon should appear there. then after you click on the icon it should bring up a page containing folders "on" your mp3 player. there doesnt have to be any music or videos or anything like that to have the folders already on there. now i dont have a mac but what i suggested you to do should work.
Sep 14, 2008 | SanDisk Sansa e200 MP3 Player
My computer won't automatically download the ez-installer to my computer, how else can I get the cd to run?
hi. i also have the same problem. i cant install may mp3, my computer cant recognize my mp3 player. i tried installing the disk but it wont install because im using vista. i tried searching over the net for installer but cant find one. please help me please. thanks
Jul 11, 2008 | SanDisk Sansa m200 (2 GB) MP3 Player
I want to delete some files off the sansa. I thought that deleting the files off the computer would solve that problem. It didn't. I did however conect the sansa to the computer while trying to delete the...
Please give me a response on how to solve deleting from MP3 sansa m200 series.
I downloaded a cd to my sansa now how do I go about deleting from the player.
I'm on window media player 10 Thanks.
Feb 27, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa m240
You do not need anything from the CD, it only has Windows Media Player 10.
All you nee is a PC with XP / SP 2 and Windows Media Player 10 or higher. No drivers are necessary.
Best of Luck.
Please RATE my solution BELOW.
Nov 22, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
My MP3 Player will not recognize my songs.
1) Songs in wrong format
2) upgrade to Windows Media Player 10 or 11
Aug 27, 2006 | SanDisk Sansa m200 SDMX3-512 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
183 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
