Question about GE Profile JGS968 Gas Kitchen Range
No lights on the panel..
The lights are not on the panel, have checked the breaker...any thoughts
  • steve harris Mar 04, 2007
    i figured it out the outlet has gone bad..thanks :)
    Scholar:
  • 76 Answers
Golakers Not enough information to help you. Describe the problem more specifically and provide the complete model number. Then I'll be able to help you with diagnosis. Gendos
Posted on Mar 04, 2007
Kitchenaid refrigerator control panel
Light switch has gone bad use your model number to order a new one
Jul 25, 2013 | KitchenAid Refrigerators
We came home from a weekend vacation and the TV won't turn on at all. there are no lights, no response from the remote, nothing. It worked fine on Friday and now Sunday, it is shot. I thought possibly...
Hi, Check that the plug has power. Use a light to do this. Also check the TV cord maybe bad.
Check breaker pannel. Make absolute sure that you have power getting to the TV. If all is good you need a repairman. Good luck
Jun 20, 2011 | Westinghouse 32" Flat Panel LCD HDTV
I have bedrooms with arc fault breakers in them. Randomly, the breaker will trip for no apparent reason. Usually only the lights are on in the bedroom, and nothing is plugged in to the outlets. The room...
If your arc fault breakers are tripping, then there is an arc developing somewhere along the line from the panelboard to the rooms that the breakers cover. If they are breaking in more than one room, then the fault lies in the lines somewhere between the panel and junction to these rooms.
You would have to trace the line from the panel to each light/outlet until you find the problem. Remember the arcing could be occurring anywhere, in the line, at the light, or at the outlet.
Your brother should be able to check each section of wire for continuity rather than ripping out all the wires in those circuits.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 27, 2011 | Siemens Seimens Arc Fault Breaker
Main breaker keeps kicking, yesterday it effected the dryer, washer and lighting! Turn dryer on and lights worked, turn it off and lights would go out! Washer wouldn't run at all. Thought the house was...
I would be inclined to think the main breaker is almost worn out and needs replaced very soon.If it's taking out the main instead of individual breakers I would get a good electrician on it right quick. Good luck and thank you.
Feb 21, 2011 | Electrical Supplies
Breaker for bathrooms started kicking out-nothing is plugged in outlets when we set immediately kicks out again- thoughts on what it could be
Okay, this sounds like fun. Are you confident in opening the breaker panel and removing the wire from the breaker? Make sure that the breaker is off when you do this. By removing the wire, we determine if the breaker is faulty. If the breaker still trips when there is no wire on it, then it is faulty and needs to be replaced. Now, if the breaker is good, then take an ohm meter and check the resistance between the disconnected wire and the neutral wire (white) for that circuit. You should have the settings on the meter to the highest resistance. You should read infinite resistance, if not, then it could be a faulty receptacle or light socket in the circuit. Sometimes the plastic in the device (socket or receptacle) can develop a carbon path that may or may not show on an ohm test. When 120 volts is applied it arcs and sometimes shorts out. Assuming that you have a low resistance you need to find the device that is faulty. If you have a high resistance, you will still need to find the fault. Reconnect the wire, and leave the breaker off, and you should remove a device on that circuit and by process of elimination, check the circuit one device at a time.
Feb 16, 2011 | Eaton ARC FAULT CIRC BREAKER
The heat dry light on my dishwasher is stuck. can't start a new cycle, can't do anything. thoughts?
Only one comes to my mind.. kill the breaker in the main breaker panel for your kitchen, or dishwasher... See if that works.
Jan 03, 2011 | Frigidaire 24 in. FDBB540 Built-in...
How do I run from a 100 amp main panel to a 60 amp subpanel, 125 from my house to the garage
See 60 Amp sub-panel image
Above image shows drawing of 60Amp sub-panel located next to main panel. Drawing shows #6 wire... 125' distance to garage calls for #4 wire. I ran #4 to my barn and have no problems.
Give thought to how many new breakers you want at garage.
See photo of subpanel that holds three 240V breakers
Using drawing as a guide. Replace existing 240Volt breaker with new 60 Amp breaker. Two hot wires connect to new 60 Amp breaker. Neutral connects to neutral busbar.
More space: You can free up space in main breaker box using a tandem breaker. Or by doubling up 2 lightly used 120V circuits onto one breaker. Do not double-up on 240 Breakers
Conduit: You want PVC conduit large enough to fit three #4 wires. Bigger conduit is easier to pull wires ... and maybe later ethernet wire, or alarm wire etc.
Ground wire: You can put a ground rod at garage and run #6 bare copper between sub-panel neutral-busbar and ground rod. Attach ground wire firmly with grounding clamp.
I want you to check with local electrical supply for exact code in your area concerning conduit requirements, grounding, and wire size. Tighten all lugs very tight against wire.
Oct 03, 2010 | Siemens 100 Amp Main Breaker Renovation...
GE THQB 1 pole 20 Oily liquid appears to be seeping from multiple breakers, different panels but not all breakers. Breakers installed 1992. Any thoughts?
There is no liquid in those breakers to seep out... my thought would be that some one used an anti oxidate compound on the wires when they installed them and that is running a bit as the breakers and wires heat and cool....
I would just check the wire connection for tightness and as long as the connections are tight I would not worry about it...
heatman101
Sep 03, 2010 | GE Circuit Breaker THQB BoltOn 1 Pole 15...
Had electrical circuit breaker (240v) change out.
check where the pigtail connects to the drier.
Dave
Feb 22, 2010 | GE DBXR463EBWW Electric Dryer
Timer doesn't come on after being set. Operates landscape lights
Check your circuit breaker that feeds the timer circuit in your main electric panel. It may have tripped. Sometimes when a breaker trips it's hard to tell visually, so turn the breaker off, then back on.
Also, the circuit that feeds the timer may be on the load side of a GFCI receptacle. Look for one that has tripped. Sometimes they are found in obscure places.
Apr 26, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
GE Profile JGS968 Gas Kitchen Range Logo
74 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
