Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I lost my restore disc for windows xp.
My IBM desktop needs to run the system restore disc to fix a problem in the start up process. The error screen appears right after starting it up. My restore disc is gone, and i really can't afford to buy another xp program. Please help. thank you
Restore windows xp home basic to factory settings
Hi coz352...
Select models of Acer computers, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Sep 19, 2011 | Acer Aspire 3680 Laptop
My. IBM. Desttop computer, my data is corrupt,lost. Can't. Start up load up window xp.I do not have my restore recover disc.
hi
are you able to boot up the system, ladylegs ? if so, youc an create your own restore disk. In order to help further, i need the model and type of the computer .
if you need the restore disks , you can get that sent to you for about $50
do you want to try ?
thanks for using FIXYA
Apr 13, 2011 | Microsoft Windows XP Professional
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
How do get to the restore options? f key? ibm m 8147-23u desktop
Dear Sir,
plz use this step for restore
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section
Apr 16, 2010 | IBM ThinkCentre A50 PC Desktop
My xp pro on Dell gx150 not saving settings
Try to use the System Restore, this process will fix all system errors in your computer.
In your desktop screen, go to:
  1. Start Menu
  2. All Programs
  3. Accessories
  4. System Tools
  5. System Restore
  6. In the System Restore Window, choose Restore my computer to an earlier time.
For example: Today is March 22, try to locate the date were your computer is in perfect condition.
7. Click Next
8. Then you'll see some marked dates
which means those are the dates to use
the system restore
9. Choose a date, then click Next
button
10. Your computer will automatically
restart then wait for the process to
finish
11. A message will appear that states
your computer is successfully restored
12. Then observed the changes in
your computer system
Mar 22, 2010 | Dell OptiPlex GX150 PC Desktop
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
I want to reset my IBM thinkPad R50e back to Factory settings, I am running Windows XP Proffesional and have no restore disc.
CREATE A BACK OF DATA INIT
BETTER THEN RESTORING U CAN RESTORE UR SYSTEM TO A PERIOD WHEN UR THINKPAD WAS RUNNING SUCCESSFULLY AND THIS DOESNT DELETE ANY DATA ON UR HARD DISK
START PROGRAMMES ACCESSORIES
SYSTEM TOOLS SYSTEM RESTORE
THIS WILL SURELY HELP U
Aug 25, 2009 | IBM ThinkPad R50e Notebook
Windows Xp on Intellistation Z Pro type 6221
A restoration disc is not a conventional Windows OS disc (and vice versa), therefore it often cannot be used as if it were a true Windows disc. The restoration disc includes the OS, but it also includes every driver and other software product that came with your system. If Windows were the only item loaded on your system, then a Windows disc could serve as a restoration disc, but these days, using a typical restoration disc is an all-or-nothing process.
A restoration disc is your ultimate troubleshooting tool. Suppose that your copy of Windows becomes damaged from a virus or key applications become corrupted. Symptoms such as instability, crashing, indecipherable error messages, and impaired performance are extremely hard to diagnose by yourself—even if you have the help of a customer support technician on the telephone. If the most common corrective steps fail, you can always use the restoration disc to recover your PC back to its known-good, factory-fresh state.
Jun 18, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Active desktop recovery
This program will remove those antispyware
Download
Mar 25, 2008 | Dell Microsoft Windows XP Home Edition
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
21 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
