Question about Maytag Atlantis MDE6400AY Electric Dryer
Dryer not running has current
My dryer has power going to it as the light works when the door is open after that it is down hill, The timer doesn't run down with the power plugged in . The thermal fuses are fine all the wiring is fine that I can see or test. So any suggestions before I start ordering parts?
    Scholar:
  • 76 Answers
Zedlast Did you check the door switch? If the door switch is fine, reset the circuit breaker. If it does not help then check the power cord connection to the dryer. One of two hot wires could be loose or burned out. If nothing of the above helped, let me know. Gendos...post back
Posted on Mar 04, 2007
Maytag Atlantis MDE7400AY Dryer pull knob not engaging dryer, changed it, still doesn't work. Please help! : )
If it won't run at all that probably is due so some sort of lint build up. To get into this dryer you remove the door first and since it is reversible you remove 2 screws on the opposite side as well and then the goalpost shaped front can pop off there. Then you remove the 2 things that hold down the top to the frame. Then you can remove the shrould. Then you can get the drum out. On the blower housing is a round fuse most likely it is blown. Their is another one just like it also near the blower. Check it as well. Clean her up and look for a loose blower wheel. That can cause the fuse to blow also. Now HERE IS YOUR SERVICE MANUAL. When did you say them cookies was gonna be ready? LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 09, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
The timer is running but the dryer will not come
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Oct 03, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Maytag dryer sdg515daww stopped working.
I assume this is Gas dryer from the model number having a G.
The door switch may cause the problem. If its not running the dryer thinks the door is open? And the light will also stay off. You can jump around the wires on the door switch and see if it works then if so its switch time.
I don't think a thermal fuse should have anything to do with the light. But that's not a bad idea for quick trouble shooting if a manufacturer would do it. Use a volt meeter to verify the voltage you may have enough for the timer to make noise but not enough to make it turn and the dryer to run.
If there is power then try rotating the tub slightly. The motor may have stuck. Don't turn it too far unless you know which way the drum turns. and try alkways to turn it that direction. Keeps your belts on.
If this helped you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag MDG2706A Gas Dryer
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Timer motor keeps running on dryer
sometimes as a timer gets older the timer motor will get a little loud. timer motors run even when the door is open. if the timer advances to off and everything works fine you don't need to worry about it.
Nov 19, 2008 | Dryers
Whirlpool dryer problem
dryer works but does not heat up
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
71 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
