Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
How do I find out if my router has the ability for me to set a timer on it? My son stays on the PC much longer than he is allowed and coming short of shutting off the internet all together I need to know if the router I have has this ability. Westell Model 327W ADSL+versalink
  • JDTec
    JDTec May 11, 2010
    And does he use the main computer or his?
  • JDTec
    JDTec May 11, 2010
    Do you have XP or Vista?
    You can set XP to set the time allowed on the unit.
    Genius:
  • 1,269 Answers
Your router model doesn't have that capability. I know a router that is capable of internet timer. That is called "Access Rules". Try the Linksys model RV042 router. If you want a wireless router, model number is WRVS4400N wireless router.
Posted on Dec 11, 2008
My son change the name on my router and he has my router locked out and i cannot get on my wifi
Hi Keith,
If the username or password has been changed on your router and you are not able to get those from your son for whatever reason, I'm not sure you are going to have many options good options. You may need to perform a factory reset and then rerun the router's initial configuration process. That will reset the router to the default username and password, allowing you access and the ability to complete the re-config.
IMPORTANT NOTE: This process WILL reset all other information currently in the router's config: The "external" IP address, the internal addresses, the WiFi settings, the visible Wifi SSID, the WiFi passwords, etc.
To reset the router to its defaults, there is usually a small (red) RESET button that can be pressed with something like a small pin. While this is pressed in, plug in the power. Hold the reset button for a few more seconds and then release it.
I would suggest that you find your exact model on Netgear's site to find the exact process factory reset. If you don't still have it, you will probably be able to find the initial startup and/or user guide there as well.
I hope this helps.
-Kevin
Dec 30, 2011 | NetGear Computers & Internet
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
I can get a strong signal on my sons netbook but when i go to go on the internet it will come up and say can't find page. what do i have to do?
Have you put an encryption key on the router? If so, have you entered this key in your sons netbook? It may be getting a strong signal but unless it is recognised will not be allowed to connect
Dec 28, 2010 | Computers & Internet
I installed a t 104 timer on my sons water heater with the wires from the panel to line terminals 1 and3 and the load to water heater to terminals 2 and 4. the ground wires to the ground screw i set the...
You have wired it correctly assuming this is a 230V water heater. The timer should have come with the motor connected to terminals 1 & 3. You should be able to see two small wires coming from the rear. These are the motor leads. Make sure they are on terminals 1 &3 also. Check for 230V on the 1 & 3 terminals with the load off just to be sure you didn't accidentally reverse the line and load. Check to be sure timer motor is running. GOOD LUCK!
Aug 02, 2010 | Intermatic T104-20 Indoor Hot Water Timer
I use to be able to conect to my company vpn, since i added my belkin wireless G router (fd7230-4)for my sons laptop i am no longer able to do so. Any help would be welcomed. My IT guy says that our...
See if Belkin has a firewall setting in the routers control panel. You have to log on to the routers address to find out. In order to access a linksys control panel you have to put 192,168.1.1 in to internet explorers address bar. The user name by default is Admin and password is the password. Try doing a google search for the belkin log on address to use.
Jul 01, 2009 | Belkin (F5D7230-4) Router (587009)
My son wants to do xbox live but cannot gain access to our wireless router. I have a vista pc connected to the router and 2 other computers in the house that connect fine. Help me please...son driving
Please open your router page and open the DMZ page give an IP address.
Then open X-box page and force the same ip address it will allow your x-box to communicate with the router.
May 21, 2009 | Linksys Wireless-G WRT54G Router
Wireless 108G MIMO Router Model DI-624M
Tell your son to change the MTU settings on the router, especially if you have DSL.
Changing MTU on router
Step 1.
Log into your router by open your Internet browser (e.g. Internet Explorer), enter the IP address of your router (e.g. 192.168.0.1) and press Enter. Specify username (admin) and password to log into the router.
Step 2. Click on the Home tab and click on WAN on the left side.
Step 3. Look for the MTU field (note that it may not be available in some router models). The default MTU value is 1500, change it to lower number, e.g. 1200.
Step 4. Test your ability to connect to those specific sites youre having trouble with. If changing the MTU rate to 1200 does not resolve the problem, start lowering it in increments of ten until the problem is resolved (you may need to go as low as 600 depending on your DSL connection).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 01, 2008 | D-Link DGL-4500 Wireless Router
Security
log-in to your router,go to access restrictions....status..click enable....click on Edit List of PCs......enter your son MAC address or his IP address.....save settings.....and after that you just have to set the days and hours when he could go on-line
Feb 02, 2008 | Linksys Wireless-G WRT54G Router
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
105 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
