One is both transmitting and receiving, the other only receiving. I've been thru all the settings and they appear to be set correctly and the same. Ideas? And also the charger doesn't light up. They are a year old, but never used and both batteries are previously fully charged and still showing ample charge.
Swap batteries between the radios and see if the problem moves to the other radio.
If your charger does not light up, it is not working. So your battery may not be getting fully charged. The first sign of a poorly charged, or bad battery is no transmit.
If these do not solve the problem, and your settings are identical, you may have a faulty radio. Double check your settings, and take them back to their simpliest form, shut off any special features and make your PL code be off or zero. Then try the radios, if they still don't work, you have one radio which is bad.
best regards.
SOURCE: low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
SOURCE: oregon scientific walkie talkies
Hi Neil
You can obtain the Owner's Manual (Contains simple instructions) from link below
http://www.expressfix.net/manuals/2WayRadios/OregonScientificTP329
SOURCE: model #LI 7700 serial# R811004738 walkie talkies do not charge
Hello ddzepp;
I apologies but this site does not represent any manufacturer or company. This site is made up of many technicians like my self that volunteer to help others with technical issues concerning thier equipment. As for your problem you would need to contact the company that makes your product and ask them to resolve your issue with this charger.
Patrick Patterson - N5SLI
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
SOURCE: We have a set of
Here is a link to the user guide: http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=252
If the icon you are referring to is a little radio picture, this would indicate the radio is in transmit mode. This possibly could be due to being in VOX mode, or Baby Monitor mode, or it simply could indicate their is a problem with the radio. Problems might include: sticky PTT button, an audio device being plugged into the accessory jack while the radio is still turned on, debris in the jack, or a damaged jack.
Best regards.
