Question about HP PSC 1315 All-In-One InkJet Printer
New 9800 will not print--spits out paper.
I have downloaded the driver that came with the printer, and one from the net, but it still won't print. I checked the port--o.k. I removed the printer and put it back on the system--same result. It has power--green light on. Have tried all the troubleshooting steps--no results.
    Master:
  • 479 Answers
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Posted on Dec 10, 2008
Service manual hp 9800
I have an HP 9800 Deskjet that I print heavier self stick vinyl paper. The print comes out wavy. Lines aren't strait and images get blurred. Seems like the rollers might be worn causing it not to pull paper in right and centered.
Mar 25, 2014 | HP DeskJet 9800 InkJet Printer
HP photosmart c8100 all in one printer 10x15 photo paper spits out when ever you try to print a photo from printer .new printer thanks Ray
do the normal copies of microsoft worf comes out properly without any spitting.then its the setting problem in your printer .you can change the settings through printer properties --just adjust the photo settings in your printer and it will print the photos.
but if the word document are also having the same problem its the printer problem get the replacement as the printer is new.
feel free for further queries.
thanks.
Sep 20, 2008 | HP Office Equipment & Supplies
Hp printer won't print mac word doc
I wonder whether the Word Doc SDK I am testing these days can help with the related programs?
How to Get Started with VB NET Word
May 01, 2012 | HP Officejet 6500 AllInOne InkJet Printer
Hp 9800 prints only quarter page
Try sending less pages to print and see what happens.
Try one to test and if it workks then send 24 of the 48 pages and finally the rest.
Aug 28, 2009 | HP DeskJet 9800 InkJet Printer
Sensor error in the Epson stylus pro 9800
sounds like you need a new sensor. call tech support
Dec 10, 2008 | Epson Stylus Pro 9800 InkJet Printer
Printing Problems!!!!! Help!!!!!!
You have the wrong drivers in your computer, go out to hp.com and download new drivers and software, once installed you should be inbusiness.
Aug 06, 2008 | HP PhotoSmart C4280 Laser Printer
Too Much Paper
2 possible solutions.
1 The paper itself. Check that the paper tray is not overfull. this can cause multiple sheets to feed through. Also make sure that you use good quality paper suitable for the particular type of printer. Always keep the paper dry Damp (not wet) paper will also cause the sort of problem you describe. another good reason for not keeping to much paper in the paper tray. Paper will keep better in the packet than in the tray. Always store the paper in the packet in a warm dry place. I keep mine near a radiator and away from the Air con.
2. The printer driver. Download the latest driver for your printer from the manufacturer and update the printer driver, via the control panel/printers. If you don't know how to do this you can simply uninstall the printer and then install it again using the new printer driver.
Good Luck
Carrieone
Apr 02, 2008 | HP Photosmart 7450 InkJet Printer
Printing on 4 by 6 photo paper
What program are you trying to print from? and where are you selecting the paper size from? Make sure 4x6 is selected in the kodak driver and 4x6 is selected in the page set options in your program. Other wise you may need to download new software and firmware from the Kodak Site.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP 9800 DeskJet
These printers usually determine whether paper is loaded by using a simple sensor with a small plastic arm. The paper lifts the arm (or pushes it down, depending on the design) when it is put into the printer. Take the paper out and look for that plastic arm - if it's broken, or the spring that holds it in place has come loose, that's the culprit. If that's not the problem, then it's probably going to be something you can't fix yourself. In that case, replacement is usually cheaper than repair for most inkjet based printers.
Aug 27, 2007 | HP DeskJet 9800 InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
Ben Johnson
