Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint vtd20 dryer aquarius - cuts out when overheats
I have a 2nd hand hotpoint vtd20 tumble dryer aquarius model. Only a couple of small problems with it. One is the door handle is slightly broken so sometimes hard to open (anyone know if i can get parts to repair it?) and also if it sometimes cuts out after a bit of time and fuses all electric appliances. Any ideas? Would be grateful for any advise. Caz
  • Hotpoint Master
  • 3,463 Answers
You can get spare parts on line by going to,
www.hotpoint.co.uk
Re your other prob ,it is probably due to a fault with the heater, disconnect the heater and run the dryer .if it does not cut out then your heater needs replacing.
Posted on Dec 11, 2008
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Aug 06, 2013 | Dryers
Cant get top off dryer vtd00
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
My Hotpoint Aquarius TDL30 is working all fine apart from no heat. Is there a quick/simple fix I can do, or is it an engineer job, or a new machine? Thanks Andy
There is a high probability it is a thermistor tripping out. It cuts power to the heater or fan, or both if the tumble dryer overheats.
UNPLUG THE MACHINE FROM THE WALL BEFORE PROCEEDING.
At the back of the machine, you will see a bulge, held in place by half a dozen or so screws, that covers tha fan and heater element. Once removed, you will see the heating element and the thermistors (I think there are 3 on this model). The thermistor is round, about the size of your thumbnail, set into an oval metal casing, usually with 2 holes in it to mount it and a couple of spade connectors coming off it..
(See a picture here: http://www.espares.co.uk/part/tumble-dryers/thermostats/indesit/isl70c/p/1587/805/0/552087/552036/tumble-dryer-thermostat-k.html)
Typically, the back of the centre thermistor will have a small hole in it that you can poke a paperclip end into.
Basically, the thermistor is a convex bi-metal disc that, when it gets too hot, pings and becomes concave, by pushing a paperclip into the hole, you push out the disc and make it concave again (You will hear it click as you push the pin in).
This is usually all that you will need to do to fix the problem. However, if it was an overheat trip out, you need to ask yourself why this happened. There are usually 2 possible causes:
1) The dryer was overloaded
2) The filters were clogged
3) The heating element is faulty and requires replacement.
1) Is very unlikely. 2) is the most common culprit. 3) will show its self if you clean the filters and the problem keeps reoccuring. If you do have to swap out the heating element, you will find they are easily available on Ebay.
Aug 23, 2011 | Hotpoint TDL15 Electric Dryer
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Tumble dryer drum won't turn
Jul 06, 2009 | Dryers
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Jan 23, 2009 | Dryers
Tumble dryer
Go to:
www.hotpoint .co.uk
Click on After sales, then on download user instruction books, put in you model number, and down load to your computer, or your printer.
Problem solved.
Plz rate my solution.
thanks, and merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
368 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
