Question about IBM ThinkPad T23 2647 Notebook
My hard disk can't be formatted when I try to install Xp.
It doesn't accept to be formatted it causes an error
  • Nicolas
    Nicolas May 11, 2010
    And what is the error code?
  • 3 Answers
If u r sure your hdd is not broken.remove ur memory stick and video card (if any) then clean the golden terminals with the pencil eraser , re-insert it. try to format it again. be sure u have selected the first drive to boot is ur cd drive. if this doesnt work, its time for u to buy a new hdd. i hope this can help.
Posted on Dec 10, 2008
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
I tried to install the XP in my laptop compaq c700 (vista basic ) getting the error " replace the hard disk"
Greetings my friend, please try to format first your hard disk before installing Windows XP to prevent error causing by the vista operating system setup settings.
Thanks
Jan 07, 2010 | Compaq Presario 700 470024-192 Notebook
I cant reformat my hard drive. (Windows XP)
Hi. There are several causes for this type of error. Either your Windows CD is corrupted, hardware is faulty (Motherboard, RAM, hard disk, video card, etc.). You may want to try to reformat your hard drive using another computer first just to isolate if your hard drive is faulty. If you can format it using another computer, try installing windows on that computer.
Aug 27, 2009 | Microsoft Windows XP Professional for PC
Can't install OEM Windows XP on fresh hard disk
please check the consistancy of hard drive or try to run a zero format first and then reinstall the win
Apr 15, 2009 | Computers & Internet
Cannnot open windows
i think you will have to try to install a fresh copy of windows i suppose you are using Windows Xp, try repairing it but dont press "r" when it tells you that there is windows loaded, press"r" on the second time, this might repair your os, but see that in any case u dont allow the computer to get formatted. if it tells you that the hard disk is corrupted and u need to format it dont format it cause u say that there is important data inside, so remove the hard disk from the computer and connect it to one of your friends computer take out your data and then format the hard disk and reload the software once again
Dec 19, 2008 | Toshiba Satellite 1415-S173 Notebook
New Hard drive xp install
If your hard drive is SATA and your windows disk does not have SATA drivers on it it will not find the hard drive this is your problem
http://driverpacks.net/DriverPacks/
Go to the above site and download "driverpack mass storage" and slipstream into your windows CD.
I have done this with one windows install disk that could not find disk then it worked perfectly
Nov 05, 2008 | Abit KT7-RAID Motherboard
Onlly 2 GB shown on a 10 GB Drive
try to check whether the disk jumper is correctly placed then use another os to format the hard disk i.e os win xp
Mar 26, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
Hard disk is not responding while installing os
1st plug any hard disk of urs and get a bootebel cd u can say not the xp 1 but u can find old cds like windows 98 or milenium and boot it..after sellect the cd rom support aplication..wen loaded right fdisk select yes and yes..after that delet dos or any existing partitions and restart do the sam thing again but this tim make dos partition wen ur finish restart and go in again but wen loaded on a:\ wright format C: and accept..after format is finished retstart but this time boot frome windows xp or the operation system disk u want 2 install..and folow the instruction..and if i didnt work after u do all that u go 2 ms dos and make a scandisk for c after u format u can see all comands in a:\dir , thats all and 4 the other hard drive u dont need 2 do the same just after u install widows u plug it and go 2 cotrol panell in administrative tools and select the icon that have a pc signe and after that frome the second option u select the 3 and u see ur second hard disk format it and scan it and evry thing will be just fine........
Feb 04, 2008 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
IBM ThinkPad T23 2647 Notebook Logo
37 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
