Question about Microsoft Xbox 360 Console
360 wont turn on
I played my 360 for 15 min than i turned it off. about an hour later i went to turn it on again and it wouldnt turn on.I unplugged it and plugged it in somewhere else(not connected to the tv) and it turned on and i got the full red ring. When i hooked everything up and back into the tv it workd fine and the red ring went away.The next morning i woke up and tryed to play it but it wouldnt turn on. I repeated everything i did last time but it didnt work. Someone help me
  • Electronics Repair May 11, 2010
    Do you get green light on the power supply?
    Does the fan come on when you turn it on?
  • 72 Answers
Hi there, This issue may be caused by your power supply and or console not getting good enough ventilation or air vents clogged with dust causing over heating. Check power supply and keep in wide open area same with console (not sitting on carpet). If over heating is the issue you may have warped your motherboard, what happens is the Graphics processing unit (GPU) and or Central processing unit (CPU) get extremely hot causing the mobo to warp and the solder becomes loose and break. Even the fan may be the culprit, the fan uses a lot of power and produces a fair amount of heat that can cause the system to over heat. Please contact microsoft and get system repair if problem persist.
Posted on Dec 11, 2008
Car ran fine drove it twenty min went to start it again wouldnt start went back an hour later started right up drove it 15 min and it died again changed the plugs and fuel filter still wont start
This sounds more like a crankshaft position sensor. When they start going bad they will work when vehicle relatively cold but fail when hot.
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
Jan 02, 2011 | Nissan Altima Cars & Trucks
Security light flashing while driving then suddenly wont start
sounds like you need a new ignition switch the pass lock is screwing up common.
Jul 22, 2009 | 1999 Pontiac Grand Am GT
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
May 29, 2009 | Microsoft Xbox 360 Console
This means its most likely over heating and the GPU is on its way out...
you can try using a diffrent cable see if this helps.
if not contact microsoft as they now have 3 years warrenty on them :)
thanks
alex
Apr 06, 2009 | Microsoft Xbox 360 Console
360 not reading disc
If you want to solve this problem soon then you should have to click on Solve disc wont read problem, hope its helps...
Mar 07, 2009 | Microsoft Xbox 360 Console
Xbox 360 turns on somtimes
open the xbox and fix the faceplate yourself and try getting a new power cord or a new powerbrick
Dec 09, 2008 | Microsoft Xbox 360 Console
Power button problem
As you said, its 4 months old and assumed under warranty cover. Contact Sony Service Center for repair because if you try yourself, will void warranty.
Aug 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Xbox 360
check the hdtv/tv switch on the xbox side of your AV cable if no try the towel trick toss a towel over it for an hour while it is on then turn in off let cool for 20 min then try again
Aug 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
