Question about Gigabyte GA-K8VT800 Motherboard
Ga-k8vt800m motherboard specs..
Hi... i got a used k8vt800m motherboard and is not posting start...
i wonder if the memory has anything to do with it...could it be the
memory is not compatible? i have a kingston 1gig
KVR400x64C3A/1G it came with it... i also have an AMD SEMPRON
SDA2800AIO3BA MODEL 2800+... 1.6 MHZ ...IF ANYBODY has any
experience with this motherboard and cpu please help...i like to know
what position does the cmos jumper goes normally...on or off
there are only two pins...usually there are tree..
thanks for any help rendered
  • Anonymous Dec 11, 2008
    yes... the cooler fan does spin...and the power supply powers up..
  • jshtate May 11, 2010
    do the fans spin up?
  • 86 Answers
First, remove all power from motherboard, including the Power Supply ATX plug. Then remove ram and all PCI and PCI-E / AGP (Video) cards even network cards... Let it sit for about 5 minutes and then plug in the necessities: RAM, Video Cards and if nothing works repeat the process but alternating ram slots and ram.
Posted on Dec 11, 2008
When i reset by desktop bios is not loaded (i think) black screen and not disk activity. Ga-k8vt800m. this happened after cpu frequency change.
If you can still go into the BIOS screen, disable the change you made and see if the system returns to normal.
If not, and you do not remember the settings, go for the default...
Ground yourself to the chassis to dissipate static electricity, with the system off, remove the bios battery.
This will undo any changes you made.
It will also undo and system changes that make you system unique.
At least it should start working again. You can go from there.
Good luck, and don't forget to vote
Sep 27, 2010 | Gigabyte GA-K8VT800 Motherboard
Motherboard will not run with 8gig mem
I suspect this is a memory compatibilty problem - the memory you have listed is not on the GA recommended memory list see -
Note The memory spec of what you are using is set at 2.1v yet your motherboard spec is 1.8v also the latency of your memory is spec 5-5-5-15 2t at 2.1v and 1066mhz - the motherbaord and recommended memory is 5-5-5-15 / 4-4-4-12 at 1.8v at 800mhz
Try down specing the system memory to run at 800mhz not 1066 - this will reduce your processor speed as well, but at least it might work. there is no guarantee as the latency at 800mhz is 5-5-5-18 for your memory.
Jul 07, 2009 | Gigabyte Motherboard Socket775 -...
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Post problem
You could try a program like EZ-Flash to flash the bios without using a dos disk. Gigabyte should have some type of program on their website that would do the flashing without makeing a disk as most new computers do not have a floppy drive nor does Windows XP/Vista use dos. Hope this helps.
Dec 18, 2008 | Gigabyte GA-K8VT800 Motherboard
Well my system temperature is reaching heats of 50oc under load and I believe it is making my computer freeze causing me to restart. I was wondering how exactly this temperature is measured and where...
Many motherboards take two temps. Motherboard temp and CPU temp. CPU temp is the most common problem. Check there first. You might need a faster fan or a larger heat sink. Also make sure the pc isn't enclosed in anything. It needs to have air moving around it on both main sides, the front and back.
Dec 17, 2008 | Gigabyte GA-P35-DQ6 Motherboard
No post start up
Only try to remove the cmos battery and reinsert again.......
Dec 10, 2008 | Gigabyte GA-K8VT800 Motherboard
Does Gigabyte GA-945P-S3 support 2 gb of ram
Yes, this mothereboard can actually supports up to 4GIG of RAM , so probably the problem lies on the RAM that you have, If you're using 2 or more piece or ram to this motherboard make sure they are the same brand because sometimes you will have problem like this if the memory are not the same brand...this is the link for the complete specs of the motherboard
Hope that helps..........
Sep 08, 2008 | Gigabyte GA-945P-S3 Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
The best thing to do in this situation is to build your machine outside of the case, using the minimum amount of hardware,
Remove the motherboard and using only one stick of ram, the monitor, keyboard and mouse. short the power switch connector on the motherboard with a screw driver for a fraction of a second just to power it on.
If it starts up and gives you a "no boot disk" or "no Operating System found" at least you will know it's working and you can slowly connect everything else one by one to see whats preventing it from booting.
If it doesn't start like that, remove the power cord from the power supply and remove the mother board battery for at least 15 minutes, this will clear the BIOS and set it back to factory spec, now carryout the out of case procedure already stated.
Jul 22, 2008 | Intel Motherboard
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Gigabyte GA-8IPEI000 pro-g DDR2?
Sorry your board does not support DDR2 memory. The dimm slots that you mention above are only showing you which slot is number one & number two. This does not mean the memory is DDR2. See your spec's at this link.
Jan 27, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Gigabyte GA-K8VT800 Motherboard Logo
144 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
