Question about Homelite Mighty Lite Lawn Trimmer
Homelite brush cutter zip starter has stripped..
I need spare part. Dont know were to get one.
Homelite F2020
trippssmengi
  • 76 Answers
SOURCE: Homelite
Go to www.homelite.com then in the red up top click on order parts then click launch to parts catalog then scroll down to accept agreement and then you will need to enter your model # and then you can go thru the list of breakdowns and get your part # from the diagrams.
Posted on Jan 05, 2009
SOURCE: homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Posted on Jun 15, 2009
  • 198 Answers
SOURCE: Poor running
sounds like the card needs to be cleaned thoroughly.
Posted on May 04, 2010
  • 110 Answers
SOURCE: i have a homelite f2020 series petrol trimmer i
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Posted on Jun 16, 2010
  • 189 Answers
SOURCE: how do I change the line on my 25 cc homelite zip
1) Use a pair of vise grips to open the wheel on the bottom of the feede;
2) Remove the wheel, taking care not to lose the screw inside it;
3) Remove the outside wheel, feed line into one of the interior wheels and wind it around until the wheel is full following the direction of the arrow on the outside. Leave enough line (4 - 6") to feed out the holes;
4) Repeat for other wheel;
5) Replace wheel, feeding excess line into outside wheel holes on wheel frame still attached to weedeater;
6) Hold wheel together tightly and reattach wheel hub. Hand tighten only as it will tighten itself with use and require vise grips to remove again.
Hope this helps.
Posted on Nov 02, 2010
Fuel ratio for homelite 40cc brush cutter
50:1
100ml of 2stroke oil in 5L of petrol.
Apr 16, 2016 | Homelite Garden
What is the corrector part number for carburetors fitted on homelite line trimmers model F2020 UT2078
Your missing the last digit of the model number.
UT-20788 and UT-20789 uses the UP00608 carburetor which is a ZAMA C1U-H39.
Mar 28, 2015 | Homelite Garden
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
Sep 09, 2014 | Homelite Garden
I purchased a model f2020 weed eater from bunnings naenae the line cartridge broke up and i went to get a replacement from bunnings they don't stock homelite parts but ordered one for me i have been...
You can order the part from www.homelite.com You will need your model number to help you select the right part. You will need to click on the order parts text in the upper right hand part of the screen. This will take you to another page which will ask you to go to the homelite parts catalog. After you click on the parts catalog link, it will ask you to agree to the terms of use for the website. READ THIS CAREFULLY.
After you have agreed to the terms of use it will take you to another page. From here you can input the model number of your unit. Input the f2020 into the search box and click on search. It will ask you which version of the model you have. On the right side of the screen it will have a parts breakdown. You should select (Shaft-Spool and String- Grass Deflector). This will pop up a diagram with a parts breakdown which will include part numbers to help make ordering the correct part easier. I believe the part that you wish to order is part number 17 of the diagram. When you click on the part number in the diagram it will select it below the diagram and will flash for a second. At this point it has an option to add this part to your shopping cart.
I hope this helps get you back in business.
Apr 02, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Poor running
May 04, 2010 | Homelite Mighty Lite Lawn Trimmer
Where can i fined spares for homelite f-3035 bush cutter ,thank you ,tom
Spare what? Blades, Tires, Parts. Be more specific.
Do you have a ut-xxxxx model number for this unit. The other model number you show does not come up in any data base.
Sep 24, 2009 | Homelite Garden
Need an operation manual for my Homelite Versatool
Problem solving still pending.
K.F. Cheong
Aug 24, 2009 | Garden
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Can not find parts
www.discountonlineparts.com
Apr 18, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Mighty Lite Lawn Trimmer  Logo
297 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
