Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Printer throws breaker when starting up
We moved our office to a new location and moved the printer.when we plug the printer in it starts the start up process and then throws the 20 amp breaker. we have tried it on different circuits w/ the same result
Looks like you might need to get a service tech to look at this issue. Contact me with your info we are a 3rd party vendor maybe we can help depending where you are located at.
Posted on Dec 11, 2008
Why does my air compressor motor K56A28B23 230 Volt keeps throwing my breaker.
use meter to ensure that you have 220Vac. remove cover from pressure switch and ensure that 220 vac is is applied to motor side. The start circuit may be stuck. usually the switch is located on the inside rear of motor. check centrifugal switch
May 06, 2018 | Air Tools & Compressors
I slid the printer cartridges to the middle by hand to change the cartridge. Result is that now they are printing 3 inches to the right. How do I get it to go back into left/right proper alignment?
Not sure if this will work for you. I started my cartridge up till it got to the centre and pulled the electrical plug out of the wall Took the old one out and installed the new one then re plugged the printer back in. Every thing started right up and stopped where it is supposed to be. Works like new now.
Apr 28, 2018 | The Office Equipment & Supplies
Ac electric works with generator but not when plugged in to 110 volt from the outside
I would be checking the main breakers on the panel to insure one didnt trip when you added generator electric. is there a breaker on the outside line at the box you may be missing? Also keep in mind, although uncommon, breakers do BREAK and need replacing. are you competent enough to use a volt meter to check the hot leads on the box and at your unit breaker box to insure you are getting power into the unit? In some older units the switch between land power and generator power was to manually throw breaker switches but automatic processors have replace them now... I would say start at the residential plug in and verify power is where it should be along the route of the supply cord...from the meter forward... if you have a converter plug, say from the 220V 30 amp that you are probably drawing down to 110V household, stick that on the meter and plug in your toaster to insure there is power coming in....IF YOU DONT HAVE A METER AVAILABLE... otherwise...test test test... your generator probably broke a circuit somewhere... now just to find it..
Feb 16, 2018 | RVs
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
KONICA MINOLTA PagePro 5650 error code of 0300 Polygon MOT
Polygon motor is inside the print head where the machine LASER is located the motor spins around 35,000 RPM. Moving the LASER beam across the drum with image. Sound like you need a new print head. Try the below web sit for a start.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 09, 2012 | Konica Minolta PagePro 4650EN - Printer -...
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
BROTHER MFC-7820N-SCANNER FUNTION NOT WKING
Is it still working as a copier? If so then there may be something wrong with the printer's network interface or the networking at that jack or a problem with your switch. Have you tried moving it back to the old location or plugging the network cable into another wall jack, or changing ports on your switch?
Jun 24, 2008 | Brother MFC-7820N Laser Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
55 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
