Question about HP Computers & Internet
Windows xp won't boot and don't want to resore and loose date on drive c.. can drive c be removed and used as a slave on another xp maching to recover data? recover program indicates that the drive is physically okay.
  • 586 Answers
    Yes you can attach it to another pc, And use it as slave,Moreover if you have lost data then also not a proble,You can get it back by various softwares.
And first attache it wiht some other pc and get you required things from there c: ' After that you may run windows setup and use repair option to repair the coroupt windows.
Thanks for using fixya.
Posted on Dec 11, 2008
    Genius:
  • 1,226 Answers
If the drive is still usable then you can remove the drive and then attach to the other machine and recover the data on it. see harddrive lable on connecting the hdd as slave.
However you cannot run the program installed on that machine.
melnavz
Posted on Dec 10, 2008
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
Problem loading Windows XP
You need to start windows in the safe mode, press F8 at boot up.
Remove al the drivers that you've installed on you previous computer system, usualy this is is a conflict between wrong drivers and your hardware.
If you can't remove the old drivers, reinstall Windows XP, do a clean install
by booting your computer up with the Windows xp cdrom, from the Windows XP cdrom you're also able to repartionate your hard drive.
First remove the old partition(s) en make a new one, the setup does then format your harddrive, after that you're ready to install windows xp on the new partition.
Jan 19, 2010 | Microsoft Windows XP Professional
Windows 7 on slave drive, can I format master now?
in your bios can you tell it what drive to boot from first. sorry for the lame question but im thinking its going to the defualt drive each time.
Nov 30, 2009 | Microsoft Windows XP Professional
My matser hd oin is aet to master. My slave is set
If you have the XP install disc just disconnect your master HD and use XP disc to format the slave drive. Exit after format, remove XP disc and reconnect Master. You now only have 1 drive with an OS.
Oct 05, 2009 | Symantec Norton Partition Magic-8.0...
I have used my maxtor 8 as a slave. I now wish to use it as a normal drive. My attempts to install XP produces an indication that NTLDR is not present. I have managed to start the installation program but...
If you had it set to slave status, there is a jumper on the drive controller next to where the cable plugs into. that jumper needs to be set to the correct position. typically there are 3 jumper positions Master, Slave, and Cable Select. If this is the only drive in the system, you can set it to master or cable select position. If there are multiple drives, then every drive needs to be set to cable select.
The diagram on the drive label should tell you which jumper is cable select position.
Oct 04, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
HOW DO YOU INSTALL A SECOND OS ON A SLAVE DRIVE. I AM RUNNING WINDOWS XP HOME EDITION. I WANT TO INSTALL WINDOWS 98 SECOND EDITION ON A SLAVE DRIVE DISC. SOME PROGRAMS I HAVE WILL NOT WORK ON XP.
You cannot install 98 directly on your system slave drive, but there is a way to install it.
1) disconnect your primary drive
2) make your slave drive as primary.
3) install 98
4) Connect your actual primary drive again and start your system
XP records your mac id of your motherboard and 98 does not records, the other way is, you can install both the OPS on your one primary drive by creating different partitions, you will need to full format your drive first.
1) Full format your primary drive.
2) Create partitions.
3) Install 98.
4) Install XP in different drive of your same hard disk
You will be able to see both your OPS when you start your system.
Sep 18, 2009 | Computers & Internet
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
Hard drive problem
Although I covered most of the ways to speed up Windows boot time in another article, I encountered a unique roadblock recently that made me write this article.
During the last week I was asked by a customer to upgrade one of their office computers from Windows 98SE to Windows XP. Normally this is pretty standard, however because their current hard drive was only a 20GB with a gig or so remaining I wanted to upgrade their hard drive as well.
I proceeded to ghost the drive to a larger hard drive and then installed an upgrade version of Windows XP on top of Windows 98 to preserve all of their settings and programs.
Everything went flawlessly, until I was finished...
After I completed the Windows XP upgrade, I shut down the computer completely and restarted it. The computer took FOREVER to boot into Windows XP. It was literally 2 minutes before I saw the Windows XP logo screen and another 30 seconds more before the desktop appeared. This was definitely a problem.
After checking multiple settings in the BIOS, I compared the old and new hard drives. Everything seemed to be normal, except one. The old hard drive was setup to Cable Select and as my normal routine I had set the new hard drive as a Master drive. I changed the new hard drive to Cable Select, rebooted the computer, and the Windows logo screen came on seconds after the POST screen as before. Therefore, I have to add one more item to my list of ways to make Windows boot faster. Try changing the hard drive from Master to Cable Select, check the boot up speed and switch back to Master if you don't see a change.
Master/Slave Settings
Now for a refresher course on hard drive connections. When connecting more than one hard drive to a computer on the same IDE controller, you generally have to assign one as the primary (master) and one as the secondary (slave). You do this by changing the jumpers on the hard drive next to the power connector. Normally, the drive will have a diagram to let you know which jumper should be set for a master drive and which to set for a slave drive. You'll notice in the picture below the jumpers are circled on the end of the drive and the top of the drive shows the diagram to follow.
After changing the jumpers, connect the hard drive cable from the motherboard to the hard drives. Under normal circumstances, the end of the drive cable attaches to the Master hard drive, while the inside connector on the cable connects to the Slave drive.
What About Cable Select?
Cable Select (CS) settings were designed to make it easier to connect hard drives because you didn't need to bother with setting the Master/Slave jumpers. You just connect the drives and depending on where you connected them to the cable the computer would know which is Master and which is Slave...in theory. Now comes the confusing part.
With cable select, you first needed a special 40 conductor IDE cable that would determine master/slave connections. This was different from the normal IDE cables at the time. Also, the Master connector on CS cables was the inside connector not the end connector. This made for a very confusing switch from everyday master/slave configurations.
80 conductor Ultra DMA cables WILL determine the Master/Slave settings through Cable Select however. So as technology advances, Cable Select as a concept may still catch on. With the newer Ultra DMA cables, you can set both drives to Cable Select (CS), connect them and they will work. Another change with the 80 conductor cables, the Master connector is on the end of the cable where it should be. In situations where you are using a newer Ultra DMA drive and cable, you can use Cable Select or standard Master/Slave jumper settings and the drive will boot properly.
In my scenario to start this article, the change from Master/Slave to Cable Select for this particular computer reduced the Windows boot time by more than 2 minutes.
For more information on Master/Slave settings versus Cable Select visit the following pages:
Mike's Hardware: How to Connect IDE Hard Drives
Configuration using Cable Select
UnixWiz.Net: Using IDE Cable Select
Oct 18, 2008 | Computers & Internet
Failed to load to windows XP
wow yea it's looking for grub/linux i did that same thing once you need the xp install disc insert that hopefully you can get into your bios then go and set it to boot from disc restart and go through the options till you get to repair and type in fixmbr
Oct 06, 2007 | ASUS P4PE Motherboard
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
