Question about Canon ZR70MC Mini DV Digital Camcorder
I cannot see out of the screen. Cap is off. - Canon ZR70MC Mini DV Digital Camcorder
  • emk2121 Jan 05, 2009
    My camcorder is on and fully charged, but the screen is completely black.  Even when I record and do a playback, it still shows black but you can here the sound??
  • soulelectric Feb 27, 2009
    In camera or record mode, I am unable to see any live footage. The screen is mostly blackened, and shows very little light in the top left corner.
  • 2,140 Answers
See this link. Canon has issued a world wide service notice regarding the CCD image sensor. If they determine that this is your problem (and yours are the symptoms of this problem), they will repair your camera at no cost regardless of warranty status.
Posted on Dec 11, 2008
How to change oil in a Honda Reflex Scooter
Things You'll Need
  • Socket wrench
  • 17 mm socket
  • Drain pan
Instructions
    • 1 Move the Reflex to a level, well-ventilated work area and lift it onto its center stand. Start the Reflex's engine. Let it idle in place for 3 minutes, then stop the engine and let it cool for 10 minutes.
  • 2 Unscrew the oil filler cap from the right engine cover, which is located near the rear swingarm below the right passenger foot peg, by hand.
  • 3 Unscrew the oil screen cap, located directly below the oil cap, using a socket wrench and a 17 mm socket. Drain the engine oil into a drain pan for a minimum of 5 minutes.
  • 4 Pull the oil strainer screen out of the oil screen port by hand. Spray the inner face of the strainer screen, facing the engine, with a parts cleaning spray to remove sediment or particles trapped in the strainer. Push the strainer screen into the engine.
  • 5 Replace the oil screen cap O-ring with a new O-ring. Screw the oil screen cap into the engine by hand. Tighten the cap to 14 foot-pounds, using a torque wrench and a 17 mm socket.
  • 6 Fill the engine with 1 quart of 10W-30 API SG motorcycle-grade engine oil, using a funnel. Screw the oil cap into place by hand.
  • 7 Start the Reflex's engine. Let it idle for 3 minutes, then stop the engine. Check the oil level, using the dipstick built into the oil cap. Add 2 oz. of 10W-30 API SG motorcycle-grade engine oil into the engine, if the oil level is below the dipstick's lower level mark. Do not add oil into the engine, if the oil level is at or near the center of the dipstick's upper and lower marks. Screw the oil cap into place by hand.
  • Jun 27, 2014 | Honda Motorcycles
    My brother pr600 is stuck on cap frame how do I get it back to the other frames on the screen
    If you repost this query in a forum dealing with knitting machines and their ilk, you may find someone who can help. This forum is for queries relating to photography.
    Jun 21, 2017 | Photography
    My BB torch 9800 has been hardlock , please help me!!!!!...I Enter wrong password 10 times..I wanna help please
    Soft Reset
    Press ALT + RIGHT SHIFT(CAP) + DELETE.
    Double-Soft Reset
    Press ALT + RIGHT SHIFT(CAP) + DELETE . The screen will go blank for a few seconds. When the screen comes back on, immediately press ALT + RIGHT SHIFT(CAP) + DELETE again.
    May 25, 2011 | Cell Phones
    Compaq Keyboard -- top right hand corner, the light next to the CAP LOCK is lit. What is this for?
    Num Lock ----- Cap Lock ---- Scroll Lock
    • Num Lock --- use numeric keypad
    • Cap Lock --- all capital letters
    • Scroll lock --- stop screen from scrolling ( pause screen )
    Feb 23, 2011 | Computers & Internet
    When turn on tells me to remove lens cap , no pic
    CCD (imaging IC ) went bad and require replacement.
    Nov 15, 2009 | JVC GR-D22U Camcorder
    My quartet projection screen will not go back up. I think someone pulled it down too far.
    The problem is most likely a damaged spring end cap. As you face the screen from the front, this is the cap that covers the right end of the cylinder that encloses the screen material. The cap is held in place by 3 Phillips head screws. If you remove the spring end cap, you will see a slot in it that is designed to hold the spring assembly stationary as you pull down on the screen. If this slot is damaged, then the internal spring inside the roller will lose tension. The fix is to pull out the screen & roller assembly, roll it back up manually, then replace the spring end cap with a new one. (I believe the part # from Quartet Apollo is K0329). The cap at the other end has a cup receiver designed to accept the pin end that is on the left side of the cylinder that houses the screen material. The tricky part is fitting the pin end back into the pin end end cap. It is easier with 2 people. If you fashion a short hook out of a coat hanger. you can use it to lift the pin end into the pin end cap. There are part #'s and exploded diagrams on the Pegasus part sales website: http://shopping.netsuite.com/s.nl?c=440001. The site is down now for maintenence, but it should be back up soon. HTH
    Mar 13, 2009 | Quartet gbc 550S 71" 1:1 Projector Screen
    Video screen will not stay on
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
    Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
    Why did the cap go bad? The cap is too close to a heat sink and over heated.
    What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
    Opening the Monitor: These monitors are difficult to open.
    The two plastic pieces snap together and must be pried apart with a flat screw driver.
    After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
    Remove the cover plate and unscrew the push button circuit board.
    Unplug the monitor cords from the driver board and remove the screen.
    Unscrew the mounting screws from the power supply board and remove.
    You will need to pinch the plastic support in the middle of the board to remove.
    Cap Replacement:
    Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
    Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
    Be careful not to solder across joints.
    Keep leads long so you can bend the cap as far away from the heat sink as possible.
    Reassemble monitor and turn on.
    This should solve the problem.
    Nov 20, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
    Flat screen wont turn on
    If your screen has been damaged, you have to replace the lcd screen.
    Oct 03, 2008 | Dell E173FP 17" LCD Monitor
    Lens cap?
    Try removing the battery, wait 30 seconds, and plug it back in. That may reset the lens cap sensor.
    Aug 11, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
    15in dell monitor model e151fpb
    Cap Replacement:
    Dec 07, 2007 | Dell E173FP 17" LCD Monitor
    Canon ZR70MC Mini DV Digital Camcorder Logo
    65 people viewed this question
    Top Canon Video Cameras Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Steve Mason
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
