Question about Pioneer Elite PRO-1140HD 50 in. Plasma HDTV
42 pioneer plasm
Red light blinks five time then goes into stand by mode was told might be light lamp ?? Is that correct
    Novelist:
  • 152 Answers
Hello, your plasma activated a shutdown circut. something caused a fault in one or more of your internal circut boards. it is common it happens alot with these plasma tv's. it happens if theres something wrong internally. this is protecting your plasma panel from further damage, i dont think it has anything to do with the back light that is lcd. this is for main plasma panel protection .
blinking lights mean theres a problem with the power supply load voltages and the plasma main panel will not powered up fully.
it can be a number of different situations or even a fuse, what you can do is find a qualified service center online that offers free in home estimates, you can asked them over the phone they will know becuase of the number of times the tv blinks. they will be able to pin point the problem and usaully it will be a matter of exchanging one or more internal boards or the power supply it self.. i had this same trouble with my panasonic th42pz700u i would suggest letting a qualified tech fix it is not easy to find the fualt without proper training, electronic testing equipment, specific model schematics and repair service manuals. they will also have to adjust the voltages when they finish so it isnt easy to do yourself besides the voltages inside are really dangerous.
hope this helps
good luck and happy holidays
Posted on Dec 11, 2008
Pioneer plasma tv model pdp436pg
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 10, 2014 | Pioneer PDP-436RXE 42 in. HDTV-Ready...
I have replaced the lamp block and now the power stand by red light is going on and of (this was a new lamp block). Do I need to reset some how?
If standby red light is blinking 3 times after three second pause then check lamp cover that has no been fixed in its place correctly, it is first thing that you removed from tv cabinet to replace lamp, make sure lamp cover is back in place properly and tight.
If standby red light is blinking more or less then 3 times, let me know to diagnose problem.
Thanks.
Sep 04, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony tv kf-42we610 tv will not come on and red light blinks three times
Three flashes usually means the lamp cover is not attached securely and the TV has gone into a "stand by" mode, recheck that the lamp,lamp door, and front panel is securely attached.
Good Luck !
Feb 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
I have a 42" Panasonic plasm. The power doesn't go on just a flashing red light that blinks 7 times. Whats my problem? Is it costly?
The 7 blinks means that the SC scan drive board might need to be replace but only after checking the voltages from the power supply. If the voltages from the power supply are normal, then proceed to replace the SC scan board.
Click here to find the board you need.
and about the cost is near to  $170. for anything else let me know. thanks.
Jan 04, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
Pioneer Elite PRO-1140HD 50 in. Plasma HDTV Logo
308 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
