Question about Maytag Washing Machines
Machine starts beeping for no reason on my maytag neptune tl. It keeps flashing OP. I even the clothes but still beeps. I can only use super wash and color setting. Also all the left side button mode cannot use. Cannot control the speed, soil level and temp control. I reset it and unplug it. Had this washer for 4 years.
  • 552 Answers
I don't know if your machine is the Neptune series. If it is, there is a culprit called the wax motor in the door switch assembly that shorts out and fries the r11 resistor on the control circuit board. This could cast as much as $250 to replace the wax motor and control circuit board. It may be better to look for a new machine if it is many years old. If not, you may be able to justify such expensive repairs.
Posted on Dec 10, 2008
When I press the start botton the OP botton continue to flash, and the machine wont start.
Google "Sticky: Neptune TL Washer FAV6800AWW"
You can get the Service Manual from that site 5 post down. I have some post in the sticky for troubleshooting the OP error code along with some pics of the left hand lid lock. Post in that forum and I will help you get the machine back in service.
Mar 01, 2011 | Maytag Neptune FAV6800AW Top Load Washer
OP Flashing,beeps everytime I turn it on, lid will not lock.
I have to do a quick response take a look at this link http://www.fixya.com/support/t4615995-op_code_lid_closed and see if it will get you started.........Rich
May 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune tl washer
You will need to replace your timer control.
John
Sep 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won't Start - Beep-beep-beep
unplug it then plug it back in to see if it helps
Jan 16, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Spin Option
The problems posted by kim875 and kirsty2 all seem to be the result of faulty signals from the electronic board. This seems to be a real problem with this model machine. I would try to get board replaced under warranty , if at all possible.
Dec 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL
The washer lid is open. The lid must be closed to start cycle. Close the lid and press Start/Pause.
Aug 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Washer
if this worked fine before, then I am only guessing that the water inlet valve has malfunctioned. try filling the machine with a garden hose...any change? if still no go, then be sure to have a shop-vac handy to remove the water you just added.
May 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
164 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
