Question about Mitsubishi WS-55807 TV
Tv will not turn on / green light comes on then goes off.
I have had this mitsubishi 1081 for 6 years. Light use.
a few months back i oticed from time to time the picture was distorted
but went away after a while. Then one day i tried to turn it on and
the green light came on and it sounded like it was turning on fro a second then it went blank, The screeen never came on
I checked the fuse, its fine
  • tbeauchesne Dec 11, 2008
    Thanks. Im sure that consultation would have cost 60 bucks!
    Sergeant:
  • 399 Answers
Its the problem of the main board for sure and needs reparing for sure to make it proper.locate the faulty components and replace them.
Posted on Dec 10, 2008
Why my almost 2 year old 20" lcd tv will not come on?
If the green light is on, power is getting to the TV but there may have been an internal power supply failure
Feb 10, 2013 | Sanyo DP26640 LCD TV
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Wont turn on. Green light comes on for a few seconds, andthen goes back o0ff.
Hi if its a Lcd or Dlp rptv most likely its time to replace the lamp if tv is between 2-4 yrs.If you hear clicking it could be the ballast which is the board that powers the lamp.Make sure fans are running ok ,dust them out if they are dirty.God bless you!
Oct 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
RCA will not turn on
I had this problem on My RCA tv, what I found was a couple of bad green capacitors in power suply there are around three of them I just replaced 2 of them if I am not mistaken one of them is C120 but if not change all three this are the value of the ones I replaced 2200uf 16v and 220uf 35v, if you see on top of the green capacitors you will notice they are bad.
My tv is working for more than a months and I had the same problem as you are having.
Oct 21, 2007 | RCA HD52W58 52" TV
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
