Question about Reddy Heater-30-55,000 BTU Variable
Runs for 15 secc.'s to 1 Min. Then Shuts off...
I have a Reddy Heater 60 that has been used very little (less than 2 gallons of fuel). I purchased it in 2001 and it worked that winter. I haven't been able to get it to run correctly since. I dismantled it and checked the fuel flow; and the igniter shuts off while it is still "misting" fuel. I put a light on the Photo-electric cell and it made no difference. To get it to re-start, I must unplug it from the wall and re-plug it in. As soon as I plug it in again, it fires right up, but then the igniter shuts off and it shuts down the unit. It does not seem to be fuel delivery, but what ever causes the igniter to shut down. Any suggestions?
Steve
  • blindi2 Dec 11, 2008
    I have a Reddy Heater 36000 and it runs fine for about 10 minutes and then blows the breaker. I draws about 10Amps when running.
  • 232 Answers
Steve- You've got to understandhow it's supposed to work before you can fix it.!
  1. The ignitor only glows for 5 seconds. Just long enough to start combustion.
  2. The photocell monitors the flame color. If it doesn't like the color of the flame (or no flame at all), then it shuts the heater down. Does this sound like what may be happening?
You must troubleshoot the system and decide whether you are having a fuel delivery/mixture problem or an electronics problem.
Read these troubleshooting tips.
Good luck.
Posted on Dec 10, 2008
60 000 Btu reddy heater. Igniter fires. Good spray. Fuel. Everything ckean. Starts runs. For less then a min. Then shuts down. Checked all basics. Checked ok. Any ideas ? Photocell looks clean as well....
HI, Have you observed Thermal overload and FLA of your equipment? This will tell you what is going wrong. I suggest you to set Thermal overload = 1.15 up to 1.2 ( X FLA) For long time usage, Thermal over load also be weak. You may make trial by adjust it a little bit higher .
Dec 01, 2010 | Heating & Cooling
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
R55B Reddy Heater won't stay running. (PMS? menopause?)
Wow! Yours is the best description of a problem I have ever seen!!! Before I read the whole thing I figured you missed the pressure check as most people do but you nailed it. This is what I would try, Replace the air filter, the fuel filter, and the fuel (to make absolutely sure there is no water in the fuel) and readjust the fuel/air mixture. If that does not do it replace the cadmium cell they only cost pennies. Let me know how you make out and good luck.
hardrocko
PS, I have one of these so I am pretty familiar with the problems.
Feb 03, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ready heater forced air 60 kerosene run for 4 min or so and dyes
First CARBON MONOXIDE WILL KILL YOU
#2 fuel is too dirty, use #1 or clear K-1.
I have found when running mine in any confined space like a garage, it will consume too much oxygen if not vented. It might run till it draws down the oxygen level. You start at 21% and draw down the oxygen to 14% that is where mine kicks out.
Clean out the filter, flush the tank, put in clean K-1, You might need to replace the igniter. Check your fuel line pressue (mine was 4 psi).
Good Luck
Jan 24, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Reddy Heater-30-55,000 BTU Variable Logo
188 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
