Question about Broan-NuTone WS130 Kitchen Hood
Hoover ws130 my hoover ws130 washing machine seems to be blocked. when the machine starts, water pumps out of the detergent drawer instead of into the drum itself.i assume this is due to a blockage. what is the easiest way to remedy this problem?
    President:
  • 1,462 Answers
Take out the detergent drawer and thoroughly clean. if that doesn't work, the may be a blockage in hose from drawer to tub. take off top, remove hose and clean out
Posted on Mar 31, 2007
When we put the machine on a 90 degree washing cycle water and foam pour out from the detergent drawer
seems as if the water inlet from the detergent drawer to the drum could be clogged up might wanna have it cleaned or replaced
Jan 07, 2017 | Washing Machines
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Hi I am experiencing a problem with my hoover washing machine, when the machine is turned on it is not taking the powder from the drawer or filling with water?. It is a Family 1300 mega load hope you can...
There are a few reasons that you are having this problem.
It's possible that the hose that supplies the water is blocked. If the drawer and powder are totally dry, the solenoid that supplies the water to the detergent drawer may be bad. Some machines use hot water to dispense the detergent and cold water to dispense fabric softener, so both must be available to that type of machine regardless of the wash/rinse temperature selection.
I'm not familiar with Hoover. If you open the drawer and see a tab that stops the drawer, depressing the tab may allow the drawer to be removed and cleaned at a sink. They are not dishwasher-safe and must be cleaned by hand.
If this does not help, please repost your question.
Good luck from Detroit, MI, USA.
Jul 19, 2011 | Hoover Washing Machines
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
My machine is pumping water out the dispenser door what could be wrong
if you mean that water is coming out via the drawer that you put the powder then:
The powder has become solid in the drawer and blocked off the pipe leading to the drum.
What you need to do is to get boiling water and pour it into the detergant and using the pointy end of a wooden spoon break the sludge free in the pipe and the detergant draw.
Please leave feedback
Aug 02, 2008 | Washing Machines
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Water Leak
I have th same problem, apparently a possible cause could be a partially blocked pump filter. Just trying to get infoon where this is and how to get to it though.
Oct 31, 2006 | Hotpoint Ultima WF860 Front Load Washer
Broan-NuTone WS130 Kitchen Hood Logo
121 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Steve Allison
Steve Allison
Marvin
Marvin
Paul Bade
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
